Seit Update streiken die Einkaufswelten
Guten Tag zusammen,
ich bin etwas verzweifelt … Seit dem letzten Update funktionieren meine Einkaufswelten und die Kategorieren nicht mehr … Im Backend bei den Systemlogs habe ich folgendes gefunden:
exception ‚SmartyCompilerException‘ with message ‚Syntax Error in template „/usr/www/users/anitasg/dertee_shop/themes/Frontend/Original/frontend/listing/product-box/box-basic.tpl“  on line 9 „<a href="{$sArticle.linkDetails|rewrite:$sArticle.articleName}" class="item-box-link"></a>“ unknown modifier „rewrite“‘ in /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php:657 Stack trace:
#0 /engine/Library/Smarty/sysplugins/smarty_internal_compile_private_modifier.php(132): Smarty_Internal_TemplateCompilerBase->trigger_template_error(‚unknown modifie…‘, 9)
#1 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Private_Modifier->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#2 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚private_modifie…‘, Array, Array)
#3 /engine/Library/Smarty/sysplugins/smarty_internal_compile_private_print_expression.php(65): Smarty_Internal_TemplateCompilerBase->compileTag(‚private_modifie…‘, Array, Array)
#4 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Private_Print_Expression->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#5 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚private_print_e…‘, Array, Array)
#6 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2358): Smarty_Internal_TemplateCompilerBase->compileTag(‚private_print_e…‘, Array, Array)
#7 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r28()
#8 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(28)
#9 /engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‚" class="item-b…‘)
#10 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‚\n\n{block name="…‘)
#11 /engine/Library/Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#12 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#13 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚include‘, Array, Array)
#14 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‚include‘, Array)
#15 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36()
#16 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36)
#17 /engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‚\n\n    ‚)
#18 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‘{block name="pa…‘)
#19 /engine/Library/Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#20 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#21 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚include‘, Array, Array)
#22 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‚include‘, Array)
#23 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36()
#24 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36)
#25 /engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‚\n        …‘)
#26 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‚{block name="wi…‘)
#27 /engine/Library/Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#28 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#29 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚include‘, Array, Array)
#30 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‚include‘, Array)
#31 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36()
#32 /engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36)
#33 /engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‚\n\n             …‘)
#34 /engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‚{if $sEmotions|…‘)
#35 /engine/Library/Smarty/sysplugins/smarty_internal_template.php(187): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#36 /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(155): Smarty_Internal_Template->compileTemplateSource()
#37 /engine/Library/Enlight/View/Default.php(276): Smarty_Internal_TemplateBase->fetch()
#38 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#39 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#40 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#41
Ich habe schon versucht einzelne Plugins zu deaktivieren, leider ohne Erfolg.
Bin für jeglichen Input dankbar!
ich nehme an “original” ist ein abgeleitetes template. die änderungen an der Frontend/Original/frontend/listing/product-box/box-basic.tpl funktionieren ab 5.3 nicht mehr. daher - wenn es sich um eine abgeleitete datei handelt - mal über ftp löschen (vorher lokal speichern) . danach müsste dann alles funktionieren
Hi myartstore,
ich habe die Datei wie du vorgeschlagen hast gelöscht und das Theme dann neu kompiliert - leider ohne Erfolg.
Darauf hin habe ich einfach alle tpl Dateien in dem Ordner entfernt und siehe da: es klappt!
Allergings funktionieren die mobilen Seiten nicht…
Jemand eine Ahnung woran das liegen könnte ? :-/
Moment, ich guck mal in die Glaskugel.
Aber moment, ich nehme an, du hast das Update auf einem Staging System gemacht und nicht Live?
klappt denn alles im Responsiven Theme von Shopware selbst? Wenn ja, liegt es dann ja logischerweise beispielsweise an einem falsch umgesetzten Theme oder den Theme - Dateien im eigenen Theme (beispielsweise indem man einfach eine ganze Bare - Datei vom Inhalt her kopiert hat).
Der Fehler oben steht doch deutlich da - der Smarty Tag “rewrite” ist wie einige andere aus Sicherheitsgründen nicht mehr erlaubt, siehe: Shopware 5 upgrade guide .
Beste Grüße
Sebastian
