Hallo
Riesenproblem nach Update auf die neuste Version.
Hat jemand eine Idee???
Syntax Error in template “/fenjneqm/www.fensterbank-profi.de/themes/Frontend/Fensterbank/frontend/plugins/pixelmultioptionen/listing/box_article.tpl” on line 3 “<a href=”{$sArticle.linkDetails|rewrite:$sArticle.articleName}" title="{$sArticle.articleName}"" unknown modifier “rewrite” in engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php on line 657
Stack trace:
#0 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_private\_modifier.php(132): Smarty\_Internal\_TemplateCompilerBase-\>trigger\_template\_error('unknown modifie...', 3) #1 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(465): Smarty\_Internal\_Compile\_Private\_Modifier-\>compile(Array, Object(Smarty\_Internal\_SmartyTemplateCompiler), Array, NULL, NULL) #2 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(249): Smarty\_Internal\_TemplateCompilerBase-\>callTagCompiler('private\_modifie...', Array, Array) #3 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_private\_print\_expression.php(65): Smarty\_Internal\_TemplateCompilerBase-\>compileTag('private\_modifie...', Array, Array) #4 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(465): Smarty\_Internal\_Compile\_Private\_Print\_Expression-\>compile(Array, Object(Smarty\_Internal\_SmartyTemplateCompiler), Array, NULL, NULL) #5 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(249): Smarty\_Internal\_TemplateCompilerBase-\>callTagCompiler('private\_print\_e...', Array, Array) #6 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(2358): Smarty\_Internal\_TemplateCompilerBase-\>compileTag('private\_print\_e...', Array, Array) #7 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3101): Smarty\_Internal\_Templateparser-\>yy\_r28() #8 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3201): Smarty\_Internal\_Templateparser-\>yy\_reduce(28) #9 engine/Library/Smarty/sysplugins/smarty\_internal\_smartytemplatecompiler.php(105): Smarty\_Internal\_Templateparser-\>doParse(10, '" title="') #10 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(192): Smarty\_Internal\_SmartyTemplateCompiler-\>doCompile('\n {if $sArt...') #11 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_block.php(195): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Smarty\_Internal\_Template)) #12 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_block.php(255): Smarty\_Internal\_Compile\_Block::compileChildBlock(Object(Smarty\_Internal\_SmartyTemplateCompiler), 'frontend\_listin...') #13 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(465): Smarty\_Internal\_Compile\_Blockclose-\>compile(Array, Object(Smarty\_Internal\_SmartyTemplateCompiler), Array, NULL, NULL) #14 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(249): Smarty\_Internal\_TemplateCompilerBase-\>callTagCompiler('blockclose', Array, Array) #15 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(2493): Smarty\_Internal\_TemplateCompilerBase-\>compileTag('blockclose', Array) #16 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3101): Smarty\_Internal\_Templateparser-\>yy\_r58() #17 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3201): Smarty\_Internal\_Templateparser-\>yy\_reduce(58) #18 engine/Library/Smarty/sysplugins/smarty\_internal\_smartytemplatecompiler.php(105): Smarty\_Internal\_Templateparser-\>doParse(10, '\n\n ') #19 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(192): Smarty\_Internal\_SmartyTemplateCompiler-\>doCompile('\n\n{\* Product ac...') #20 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_include.php(146): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Default)) #21 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(475): Smarty\_Internal\_Compile\_Include-\>compile(Array, Object(Smarty\_Internal\_SmartyTemplateCompiler), Array, NULL, NULL) #22 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(249): Smarty\_Internal\_TemplateCompilerBase-\>callTagCompiler('include', Array, Array) #23 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(2388): Smarty\_Internal\_TemplateCompilerBase-\>compileTag('include', Array) #24 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3101): Smarty\_Internal\_Templateparser-\>yy\_r36() #25 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3201): Smarty\_Internal\_Templateparser-\>yy\_reduce(36) #26 engine/Library/Smarty/sysplugins/smarty\_internal\_smartytemplatecompiler.php(105): Smarty\_Internal\_Templateparser-\>doParse(10, '\n ...') #27 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(192): Smarty\_Internal\_SmartyTemplateCompiler-\>doCompile('\n\n{block name="...') #28 engine/Library/Smarty/sysplugins/smarty\_internal\_compile\_include.php(146): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Default)) #29 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(465): Smarty\_Internal\_Compile\_Include-\>compile(Array, Object(Smarty\_Internal\_SmartyTemplateCompiler), Array, NULL, NULL) #30 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(249): Smarty\_Internal\_TemplateCompilerBase-\>callTagCompiler('include', Array, Array)
