Fehler beim Ausführen von bin/setup bei Schritt 26/40
ich bekomme immer einen Fehler beim Ausführen von bin/setup des aktuellen git masters bei Schritt 26/40 mit folgendem Fehler:
Nach dieser Anleitung bin ich vorgagngen: https://docs.shopware.com/en/shopware-platform-dev-en/getting-started/system-installation-guides/mac-os-x
(26/40) Starting
> npm run --prefix vendor/shopware/platform/src/Administration/Resources lerna -- bootstrap
	> @shopware/administration@1.0.0 lerna /Applications/MAMP/htdocs/swtest/development/vendor/shopware/platform/src/Administration/Resources
	> lerna "bootstrap"
	lerna notice cli v3.16.4
	lerna info versioning independent
	lerna info Bootstrapping 5 packages
	lerna info Installing external dependencies
	lerna ERR! npm install exited 1 in 'administration'
	lerna ERR! npm install stdout:
	> fsevents@1.2.9 install /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents
	> node install
	Failed to execute '/usr/local/Cellar/node/13.2.0/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64/fse.node --module_name=fse --module_path=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64 --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v79' (1)
	> node-sass@4.12.0 install /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass
	> node scripts/install.js
	Downloading binary from https://github.com/sass/node-sass/releases/download/v4.12.0/darwin-x64-79_binding.node
	> node-sass@4.12.0 postinstall /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass
	> node scripts/build.js
	Building: /usr/local/Cellar/node/13.2.0/bin/node /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
	lerna ERR! npm install stderr:
	node-pre-gyp WARN Using request for node-pre-gyp https download
	node-pre-gyp WARN Tried to download(404): https://fsevents-binaries.s3-us-west-2.amazonaws.com/v1.2.9/fse-v1.2.9-node-v79-darwin-x64.tar.gz
	node-pre-gyp WARN Pre-built binaries not found for fsevents@1.2.9 and node@13.2.0 (node-v79 ABI, unknown) (falling back to source compile with node-gyp)
	Traceback (most recent call last):
	  File "/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 9, in
	    import subprocess
	  File "/Applications/MAMP/Library/lib/python2.7/subprocess.py", line 72, in
	    import select
	ImportError: dlopen(/Applications/MAMP/Library/lib/python2.7/lib-dynload/select.so, 2): no suitable image found. Did find:
		/Applications/MAMP/Library/lib/python2.7/lib-dynload/select.so: code signature in (/Applications/MAMP/Library/lib/python2.7/lib-dynload/select.so) not valid for use in process using Library Validation: mapped file has no cdhash, completely unsigned? Code has to be at least ad-hoc signed.
	gyp ERR! configure error
	gyp ERR! stack Error: `gyp` failed with exit code: 1
	gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
	gyp ERR! stack at ChildProcess.emit (events.js:210:5)
	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:270:12)
	gyp ERR! System Darwin 18.7.0
	gyp ERR! command "/usr/local/Cellar/node/13.2.0/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64/fse.node" "--module_name=fse" "--module_path=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v79"
	gyp ERR! cwd /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents
	gyp ERR! node -v v13.2.0
	gyp ERR! node-gyp -v v5.0.5
	gyp ERR! not ok
	node-pre-gyp ERR! build error
	node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/Cellar/node/13.2.0/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64/fse.node --module_name=fse --module_path=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/lib/binding/Release/node-v79-darwin-x64 --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v79' (1)
	node-pre-gyp ERR! stack at ChildProcess. (/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
	node-pre-gyp ERR! stack at ChildProcess.emit (events.js:210:5)
	node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1023:16)
	node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:281:5)
	node-pre-gyp ERR! System Darwin 18.7.0
	node-pre-gyp ERR! command "/usr/local/Cellar/node/13.2.0/bin/node" "/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents/node_modules/node-pre-gyp/bin/node-pre-gyp" "install" "--fallback-to-build"
	node-pre-gyp ERR! cwd /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/fsevents
	node-pre-gyp ERR! node -v v13.2.0
	node-pre-gyp ERR! node-pre-gyp -v v0.12.0
	node-pre-gyp ERR! not ok
	Cannot download "https://github.com/sass/node-sass/releases/download/v4.12.0/darwin-x64-79_binding.node":
	HTTP error 404 Not Found
	Hint: If github.com is not accessible in your location
	      try setting a proxy via HTTP_PROXY, e.g.
	      export HTTP_PROXY=http://example.com:1234
	or configure npm proxy via
	      npm config set proxy http://example.com:8080
	gyp info it worked if it ends with ok
	gyp verb cli [
	gyp verb cli '/usr/local/Cellar/node/13.2.0/bin/node',
	gyp verb cli '/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/bin/node-gyp.js',
	gyp verb cli 'rebuild',
	gyp verb cli '--verbose',
	gyp verb cli '--libsass_ext=',
	gyp verb cli '--libsass_cflags=',
	gyp verb cli '--libsass_ldflags=',
	gyp verb cli '--libsass_library='
	gyp verb cli ]
	gyp info using node-gyp@3.8.0
	gyp info using node@13.2.0 | darwin | x64
	gyp verb command rebuild []
	gyp verb command clean []
	gyp verb clean removing "build" directory
	gyp verb command configure []
	gyp verb check python checking for Python executable "python2" in the PATH
	gyp verb `which` succeeded python2 /Applications/MAMP/Library/bin/python2
	gyp verb check python version `/Applications/MAMP/Library/bin/python2 -c "import sys; print "2.7.13
	gyp verb check python version .%s.%s" % sys.version_info[:3];"` returned: %j
	gyp verb get node dir no --target version specified, falling back to host node version: 13.2.0
	gyp verb command install ['13.2.0']
	gyp verb install input version string "13.2.0"
	gyp verb install installing version: 13.2.0
	gyp verb install --ensure was passed, so won't reinstall if already installed
	gyp verb install version is already installed, need to check "installVersion"
	gyp verb got "installVersion" 9
	gyp verb needs "installVersion" 9
	gyp verb install version is good
	gyp verb get node dir target node version installed: 13.2.0
	gyp verb build dir attempting to create "build" dir: /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/build
	gyp verb build dir "build" dir needed to be created? /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/build
	gyp verb build/config.gypi creating config file
	gyp verb build/config.gypi writing out config file: /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/build/config.gypi
	gyp verb config.gypi checking for gypi file: /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/config.gypi
	gyp verb common.gypi checking for gypi file: /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/common.gypi
	gyp verb gyp gyp format was not specified; forcing "make"
	gyp info spawn /Applications/MAMP/Library/bin/python2
	gyp info spawn args [
	gyp info spawn args '/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/gyp/gyp_main.py',
	gyp info spawn args 'binding.gyp',
	gyp info spawn args '-f',
	gyp info spawn args 'make',
	gyp info spawn args '-I',
	gyp info spawn args '/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/build/config.gypi',
	gyp info spawn args '/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/addon.gypi',
	gyp info spawn args '/Users/sebastianelpers/.node-gyp/13.2.0/include/node/common.gypi',
	gyp info spawn args '-Dlibrary=shared_library',
	gyp info spawn args '-Dvisibility=default',
	gyp info spawn args '-Dnode_root_dir=/Users/sebastianelpers/.node-gyp/13.2.0',
	gyp info spawn args '-Dnode_gyp_dir=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp',
	gyp info spawn args '-Dnode_lib_file=/Users/sebastianelpers/.node-gyp/13.2.0/<(target_arch)/node.lib',
	gyp info spawn args '-Dmodule_root_dir=/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass',
	gyp info spawn args '-Dnode_engine=v8',
	gyp info spawn args '--depth=.',
	gyp info spawn args '--no-parallel',
	gyp info spawn args '--generator-output',
	gyp info spawn args 'build',
	gyp info spawn args '-Goutput_dir=.'
	gyp info spawn args ]
	  File "/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
	    import gyp
	  File "/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/gyp/pylib/gyp/ __init__.py", line 8, in <module>
	    import gyp.input
	  File "/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
	    from compiler.ast import Const
	  File "/Applications/MAMP/Library/lib/python2.7/compiler/ __init__.py", line 29, in <module>
	    from compiler.transformer import parse, parseFile
	  File "/Applications/MAMP/Library/lib/python2.7/compiler/transformer.py", line 29, in <module>
	    import parser
	ImportError: dlopen(/Applications/MAMP/Library/lib/python2.7/lib-dynload/parser.so, 2): no suitable image found. Did find:
		/Applications/MAMP/Library/lib/python2.7/lib-dynload/parser.so: code signature in (/Applications/MAMP/Library/lib/python2.7/lib-dynload/parser.so) not valid for use in process using Library Validation: mapped file has no cdhash, completely unsigned? Code has to be at least ad-hoc signed.
	gyp ERR! stack at ChildProcess.onCpExit (/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/lib/configure.js:345:16)
	gyp ERR! command "/usr/local/Cellar/node/13.2.0/bin/node" "/Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
	gyp ERR! cwd /Applications/MAMP/htdocs/swtest/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass
	gyp ERR! node-gyp -v v3.8.0
	gyp ERR! not ok
	Build failed with error code: 1
	npm WARN chai-shallow-deep-equal@1.4.6 requires a peer of chai@>= 1.9.0 but none is installed. You must install peer dependencies yourself.
	npm WARN stylelint-webpack-plugin@0.10.5 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 install: `node install`
	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
	npm ERR! code ELIFECYCLE
	npm ERR! errno 1
	npm ERR! node-sass@4.12.0 postinstall: `node scripts/build.js`
	npm ERR! Exit status 1
	npm ERR!
	npm ERR! Failed at the node-sass@4.12.0 postinstall script.
	npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
	npm ERR! errno 1
	npm ERR! @shopware/administration@1.0.0 lerna: `lerna "bootstrap"`
	npm ERR!
	npm ERR! Failed at the @shopware/administration@1.0.0 lerna script.
Execution aborted, a subcommand failed!
Schuld war die Node Version welche via Brew installiert wurde. Nach der Installation von NodeJS (LTS) via der pkg-Datei von nodejs.org hat es ohne Probleme funktioniert.
