hi.
hänge bei schritt 29/42 fest. habe alles nach dem offiziellen guide von shopware gemacht. bekomme extrem viele npm fehler im schritt 29.
habe gescheckt das das dev verzeichnis bzw die rechte beim user liegen.
hier mal anfang und ende vom log da das log an sich zu lange ist.
(29/42) Starting
> npm clean-install --prefix vendor/shopware/platform/src/Administration/Resources/app/administration
npm ERR! code 1
npm ERR! path /Users/jh/PhpstormProjects/shopware/development/vendor/shopware/platform/src/Administration/Resources/app/administration/node_modules/node-sass
npm ERR! command failed
npm ERR! command sh -c node scripts/build.js
ende
npm ERR! 2 warnings generated.
npm ERR! libtool: unrecognized option `-static'
npm ERR! libtool: Try `libtool --help' for more information.
npm ERR! make: *** [Release/sass.a] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/Users/jh/PhpstormProjects/shopware/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/lib/build.js:262:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:378:20)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
npm ERR! gyp ERR! System Darwin 20.3.0
npm ERR! gyp ERR! command "/usr/local/Cellar/node/15.8.0/bin/node" "/Users/jh/PhpstormProjects/shopware/development/platform/src/Administration/Resources/app/administration/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
npm ERR! gyp ERR! cwd /Users/jh/PhpstormProjects/shopware/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass
npm ERR! gyp ERR! node -v v15.8.0
npm ERR! gyp ERR! node-gyp -v v3.8.0
npm ERR! gyp ERR! not ok
npm ERR! Build failed with error code: 1
