Installation Shopware 6 MAMP
Eingesetztes Betriebssystem: MAC OS 10.11.6
MAMP
PHP Version : 7.2.16
Mysql Version: 5.7.26
Node:  v12.13.1
Npm: 6.12.1
Composer: 1.9.1
Ich bin vorgegangen wie unter https://docs.shopware.com/en/shopware-platform-dev-en/getting-started/system-installation-guides/mac-os-x beschrieben.
Beim bin/setup erhalte ich dann folgende Fehler beim Schritt 28/40
1 Fehler:
# Webpack Plugin Injector: Plugin "Storefront" injected as a new entry point
Building project for production...
(node:16197) DeprecationWarning: loaderUtils.parseQuery() received a non-string value which can be problematic, see https://github.com/webpack/loader-utils/issues/56
parseQuery() will be replaced with getOptions() in the next major version of loader-utils.
'/../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js\n' +
'Module Error (from ./node_modules/eslint-loader/index.js):\n' +
'\n' +
' ✘ https://google.com/#q=import/no-unresolved Casing of ./modules/sw-theme-manager does not match the underlying filesystem \n' +
' ../../../../../../../../../../../../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js:1:8\n' +
' \n' +
'\n' +
' ✘ https://google.com/#q=import/no-unresolved Casing of ./extension/sw-sales-channel/page/sw-sales-channel-detail does not match the underlying filesystem \n' +
' ../../../../../../../../../../../../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js:3:8\n' +
' \n' +
'\n' +
' ✘ https://google.com/#q=import/no-unresolved Casing of ./extension/sw-sales-channel/view/sw-sales-channel-detail-theme does not match the underlying filesystem \n' +
' ../../../../../../../../../../../../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js:4:8\n' +
' \n' +
'\n' +
' ✘ https://google.com/#q=import/no-unresolved Casing of ./init/api-service.init does not match the underlying filesystem \n' +
' ../../../../../../../../../../../../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js:6:8\n' +
' \n' +
'\n' +
'\n' +
'✘ 4 problems (4 errors, 0 warnings)\n' +
'\n' +
'\n' +
'Errors:\n' +
' 4 https://google.com/#q=import/no-unresolved'
2 Fehler:
ERROR in /../../shopwaredevelopment/shopware/development/platform/src/Storefront/Resources/app/administration/src/main.js
Errors:
Hab schon unterschiedliche Versionen (Node, NPM, PHP) ausprobiert ohne erfolg.
Bei ./psh.phar install kommt auch der gleiche Fehler.
Die Prozedur stoppt nicht sondern quittiert dies mit Erfolg.
Das Frontend kann aufgerufen werden, nur die Administration nicht.
Hierbei fehlt unter development/public/bundles der Ordner administration und deren Unterordner.
Für Lösungsansätze wäre ich sehr dankbar
