ich habe den Forum durchgesucht aber über das Thema nichts gefunden. Ich habe Ihre MAMP Installation Guide gefolgt und den Shopware lokal installiert, bin/setup && ./psh.phar install haben richtig funktioniert. Der Storefront wird fehlerfrei geladen, was ich aber in admin Bereich bekomme ist das :
Ich habe schon auch ./psh.phar administration:build ausgeführt und den Cache geleert - das alles hilft nicht und ich kriege immer noch diese Fehler.
Wobei der Output bei ./psh.phar administration:build komisch aussieht:
ERROR in ./src/module/sw-cms/blocks/image/image-simple-grid/preview/sw-cms-preview-image-simple-grid.scss (./node_modules/mini-css-extract-plugin/dist/loader.js!./node_modules/css-loader/dist/cjs.js??ref--15-2!./node_modules/sass-loader/lib/loader.js??ref--15-3!./src/module/sw-cms/blocks/image/image-simple-grid/preview/sw-cms-preview-image-simple-grid.scss)
Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js):
ModuleBuildError: Module build failed (from ./node_modules/sass-loader/lib/loader.js):
Error: Missing binding /Users/vlad/PhpstormProjects/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/vendor/darwin-x64-79/binding.node
Node Sass could not find a binding for your current environment: OS X 64-bit with Node.js 13.x
Found bindings for the following environments:
- Linux 64-bit with Node.js 12.x
This usually happens because your environment has changed since running `npm install`.
Run `npm rebuild node-sass` to download the binding for your current environment.
at module.exports (/Users/vlad/PhpstormProjects/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/lib/binding.js:15:13)
at Object. (/Users/vlad/PhpstormProjects/development/platform/src/Administration/Resources/app/administration/node_modules/node-sass/lib/index.js:14:35)
at Module._compile (internal/modules/cjs/loader.js:1063:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1103:10)
habe auch npm rebuild node-sass probiert, hatte auch nichts gebracht. Hat jemand eine Idee ?
Danke im Voraus.
