Fehler bei mysql Datenbank installation
Ich habe gerade mal versucht die Docker Version zu starten. Im Setup gibt es allerdings einen Fehler bzgl. mysql im letzten Step:
PHP Version: PHP 7.2.15
MYSQL: mysql  Ver 15.1 Distrib 10.3.8-MariaDB, for osx10.13 (x86_64) using readline 5.1
Hat jemand eine Ahnung, woran das liegen kann?
	 // Start building product category assignment
	  0/60 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░] 0%
	 50/60 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░] 83%
	 60/60 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓] 100%
	 [OK] Finish building product category assignment
	 // Start indexing datasheets
	  0/60 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░] 0%09:42:31 ERROR [console] Error thrown while running command "dbal:refresh:index". Message: "An exception occurred while executing 'UPDATE product, product_datasheet SET product.datasheet_ids = (\n SELECT CONCAT('[', GROUP_CONCAT(JSON_QUOTE(LOWER(HEX(product_datasheet.configuration_group_option_id)))), ']')\n FROM product_datasheet\n WHERE product_datasheet.product_id = product.datasheet\n)\nWHERE product_datasheet.product_id = product.datasheet\nAND product.id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' with params ["\x64\x58\xff\xc0\xfb\x1f\x4f\x7a\x83\x04\xbc\x9a\xbd\xcf\xec\xd1", "\x91\xbc\xc9\x08\x81\x34\x43\x6f\xaa\x94\xc9\xe7\x35\x87\x05\xe8", "\x9d\xa8\xb9\x90\x51\xd5\x49\x16\xac\x2f\x0a\xcc\xd1\xf4\x62\x15", "\x1e\x15\xdf\xeb\x1d\x8c\x4d\xe4\x8d\xd3\x40\x87\x1c\xe6\x21\xb5", "\xbf\x22\xaf\x64\xb8\x77\x43\xb9\x99\xa2\x5a\x8d\xdf\xe9\x80\xd9", "\xfa\x9f\x73\x47\x2d\x09\x47\x6a\xaa\xb5\xdd\x69\x16\xdf\xf7\x1f", "\xde\x56\xe8\x86\x84\x1f\x44\x9d\x98\xd7\x03\xb3\xe3\xb2\x77\x1d", "\x17\x67\xb3\x8e\x74\x6f\x4d\x2a\x9a\x6e\x77\xf9\x19\x67\xfa\x55", "\x7f\x7a\x51\xac\x33\x78\x4c\xd8\x8e\x42\xc0\xab\xab\x50\xc4\x63", "\x51\x1a\xb6\xae\x5c\x09\x47\xd6\x91\x49\xf4\x28\xc2\x45\x06\x2d", "\xea\x47\x2d\xa0\x3f\x8e\x47\x7b\xb0\xc5\xdf\xb0\x34\xf5\xef\x1f", "\x24\x18\x7d\xe3\x07\xf6\x44\xa1\x9f\xb1\x7f\x38\x90\x6e\x66\xe6", "\x7b\x53\xbb\x7b\xf8\xef\x4d\x6c\xb5\xda\x81\x41\x47\x4c\xe9\xce", "\x65\x87\x51\x14\x29\x50\x43\x40\x80\x9d\x05\x4e\x3c\x52\x91\xa6", "\x74\xbf\x50\x81\x63\x8e\x41\x03\xa5\x84\x51\x73\x63\xb4\xc2\x1b", "\x0c\x71\x69\x77\xa6\x07\x4e\xab\x8f\xed\x3f\xd5\xa8\x63\x46\xe5", "\xd0\x17\xf3\x8c\xb4\x42\x4f\x53\xb9\x4a\x85\xf0\xbb\xb2\x93\xfb", "\xf4\xd2\x62\x32\x39\x9e\x41\xc0\x98\x29\xbf\x13\xc6\x31\xbd\x29", "\x03\x59\xcd\x0e\x7a\xe4\x4a\xe9\x81\x55\x93\x0a\xc2\xad\xfe\xcc", "\xea\x9d\x1c\xc2\x7c\x49\x47\x25\xbf\x47\x65\x32\x7b\x47\x0d\xbc", "\x25\xb5\x74\x80\x8b\xee\x49\xea\xaf\xfa\x43\xc5\x20\xcb\x82\x2f", "\x49\xa7\x29\x46\x60\x93\x4f\x20\x89\xae\xe6\xb9\x48\xc2\x04\x24", "\xc2\xb1\xf3\x22\x92\xec\x49\x81\xae\x09\x5b\xf5\xcb\xa5\xd5\xfa", "\xc0\x9d\x95\x4a\x36\x18\x46\x22\x9b\xbd\x7e\x42\x57\xc1\xc5\xb4", "\xce\xb4\x96\xfd\x90\x37\x40\x65\x96\x58\xce\xd0\x0a\x66\x0f\xd6", "\xfa\xde\x11\xda\x51\x34\x4c\x03\x9a\xe5\xa8\xeb\x2b\x1a\xd9\x9e", "\x95\xaa\xc6\x3c\x72\x9b\x4e\xdc\xa2\x26\xff\x06\x09\x07\xd6\xd7", "\x83\x03\xc3\x2d\x34\x1e\x45\xac\xa1\x3a\x92\xfe\x7e\x06\x0d\xd7", "\x9c\x64\x71\x54\x17\xb6\x4d\x81\xb5\x9f\x6f\xa8\x4b\x37\xc3\x54", "\x2e\x51\xe7\x8f\x5d\xff\x49\x39\x92\x17\xee\x9d\xab\x41\x37\xfe", "\x7d\xb8\x32\xc2\x0e\xc2\x48\x08\x96\xa7\xc3\x14\x5f\xdf\x0b\x84", "\x53\x26\xc1\xaa\x04\x31\x41\xef\x8b\x65\x7c\x9b\xad\x5c\xd8\x4b", "\xec\xb0\xcf\xf2\x57\x5a\x41\x84\xb5\xd2\x93\x4e\xa7\x2b\xad\x41", "\x82\x79\x46\x4e\xc6\x9c\x4f\x07\x9d\x83\xe0\x49\x18\x22\xd7\xc5", "\x64\x0b\x5a\xe9\xec\xc2\x46\x63\xb5\x2a\x16\x0a\x2c\xb7\x8a\x81", "\xc9\x5d\x4c\xe4\x91\xdf\x44\x3b\x91\xd1\x4f\x2b\x31\x93\x65\xaf", "\x38\xb9\x2f\x9f\xb0\xd4\x4c\xe7\x88\x38\x40\x59\x3c\xe7\x3a\xfd", "\x42\x66\xd7\x57\x65\x09\x49\xb0\x9f\xd5\xe5\xe0\x48\x84\xb6\x2c", "\x1b\x5c\xaa\xb6\x8e\xd3\x43\xa8\xb2\x64\xd9\x95\xcd\x9e\x43\xfa", "\x7b\x9c\x27\xa7\x2d\x7d\x47\xf3\xbf\x85\x77\xc2\x1b\xb1\x55\x76", "\xd5\xc2\xab\x5d\x75\x73\x49\xc4\x8d\x77\x28\xf6\x28\x04\xfa\xa6", "\x8f\x6c\x6b\xc4\x59\x9e\x4f\xdb\xad\x31\xf2\xbb\x92\x96\x9b\x9c", "\x3e\xe1\x37\x35\xcb\x5b\x49\x77\x8b\xae\xd6\xa6\x40\xa1\x0c\x80", "\x0f\x35\x98\x39\x29\x38\x45\x43\xa3\x12\xda\x3a\xdc\xce\xe3\x8d", "\x7e\xfd\xde\xe9\x18\xbe\x4e\xd3\xb1\xd9\x5b\xc3\x20\xd5\xbb\x83", "\x8d\x24\x9b\x93\x41\xcc\x48\x6d\x9d\x19\x92\xf9\xe3\x7c\xdc\x9e", "\xf7\x50\x4e\xcb\x98\xf6\x4e\x4a\xbd\x74\x37\x6b\x30\x92\xc0\xc8", "\x33\x23\x16\x32\x2d\x7e\x4f\xf8\x99\x3d\xca\xdc\x0b\x81\xcb\x27", "\xc3\x42\x87\xc3\x0f\x4a\x40\xce\x8c\xbd\x76\xfa\xc7\x0f\xeb\xca", "\xe3\xc3\xc5\x4d\xf3\x44\x44\x31\x88\xf9\x70\x0a\xa1\x62\x38\xea"]:\n\nSQLSTATE[HY000]: General error: 1260 Row 684 was cut by GROUP_CONCAT()" ["exception" => Doctrine\DBAL\Exception\DriverException { …},"command" => "dbal:refresh:index","message" => """ An exception occurred while executing 'UPDATE product, product_datasheet SET product.datasheet_ids = (\n SELECT CONCAT('[', GROUP_CONCAT(JSON_QUOTE(LOWER(HEX(product_datasheet.configuration_group_option_id)))), ']')\n FROM product_datasheet\n WHERE product_datasheet.product_id = product.datasheet\n )\n WHERE product_datasheet.product_id = product.datasheet\n AND product.id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' with params ["\x64\x58\xff\xc0\xfb\x1f\x4f\x7a\x83\x04\....."]:\n \n SQLSTATE[HY000]: General error: 1260 Row 684 was cut by GROUP_CONCAT() """]
	In AbstractMySQLDriver.php line 106:
	   ?, ?, ?, ?, ?, ?)' with params ["\x64\........
	In PDOStatement.php line 119:
	In PDOStatement.php line 117:
	dbal:refresh:index [-h|--help] [-q|--quiet] [-v|vv|vvv|--verbose] [-V|--version] [--ansi] [--no-ansi] [-n|--no-interaction] [-e|--env ENV] [--no-debug] [--]
Execution aborted, a subcommand failed!
Moin! Die MySQL Variable max_group_concat sollte auf 32000 hochgesetzt werden.
