Moin,
wir haben gestern ein großes Update von Version 5.5 auf 5.75 gemacht.
Hat alles soweit geklappt. Nur leider musste ich Paypal Express deaktivieren, sonst gab es immer folgende Fehlermeldung mit Status 500 beim Checkout
BlockzitatStack trace:
Stack trace:
#0 /var/www/clients/client4965/web9958/web/vendor/symfony/property-access/PropertyAccess.php(26): Symfony\Component\PropertyAccess\PropertyAccess::createPropertyAccessorBuilder()
#1 /var/www/clients/client4965/web9958/web/vendor/symfony/form/Extension/Core/CoreExtension.php(44): Symfony\Component\PropertyAccess\PropertyAccess::createPropertyAccessor()
#2 /var/www/clients/client4965/web9958/web/vendor/symfony/form/FormFactoryBuilder.php(173): Symfony\Component\Form\Extension\Core\CoreExtension->__construct()
#3 /var/www/clients/client4965/web9958/web/engine/Shopware/Bundle/FormBundle/FormFactory.php(43): Symfony\Component\Form\FormFactoryBuilder->getFormFactory()
#4 /var/www/clients/client4965/web9958/web/var/cache/production_202110191330/pro" while reading response header from upstream, client: 79.197.230.xxx, server: xxxx.de, request: „GET /PaypalUnifiedExpressCheckout/expressCheckoutReturn/paymentId/PAYID-MFYBUIQ8A67753615742771C/token/EC-6Y6337093E698184Y/PayerID/xxx/basketId/express HTTP/2.0“, upstream: „fastcgi://unix:/var/lib/php5-fpm/web9958.sock:“, host: „xxxx.de“, referrer: „xxx://xxxx.de/holzkisten-johanna“
2021/10/20 15:32:44 [error] 10157#10157: *222809 openat() „/var/www/xxxx.de/web/themes/Backend/ExtJs/backend/_resources/images/icons/ico_growl.png“ failed (2: No such file or directory), client: 178.63.242.64, server: xxxx.xx, request: „GET /themes/Backend/ExtJs/backend/_resources/images/icons/ico_growl.png HTTP/1.1“, host: „xxxx.xx“, referrer: „xxx://xxxx.xx/backend/“
2021/10/20 15:42:03 [error] 10157#10157: *227289 FastCGI sent in stderr: „PHP message: PHP Fatal error: Declaration of Symfony\Component\EventDispatcher\LegacyEventDispatcherProxy::dispatch($event) must be compatible with Symfony\Component\EventDispatcher\EventDispatcherInterface::dispatch($eventName, ?Symfony\Component\EventDispatcher\Event $event = NULL) in /var/www/clients/client4965/web9958/web/vendor/symfony/event-dispatcher/LegacyEventDispatcherProxy.php on line 56“ while reading response header from upstream, client: 79.197.230.188, server: xxxx.xx, request: „GET /PaypalUnifiedExpressCheckout/expressCheckoutReturn/paymentId/PAYID-xxx/token/EC-xxxxxx/PayerID/xxx/basketId/express HTTP/2.0“, upstream: „fastcgi://unix:/var/lib/php5-fpm/web9958.sock:“, host: „xxxx.xx“, referrer: „xxx//xxxx.xx/flaches-gewuerzregal-wilma-geflammt“
2021/10/20 15:43:20 [error] 10154#10154: *227787 FastCGI sent in stderr: „PHP message: PHP Fatal error: Declaration of Symfony\Component\EventDispatcher\LegacyEventDispatcherProxy::dispatch($event) must be compatible with Symfony\Component\EventDispatcher\EventDispatcherInterface::dispatch($eventName, ?Symfony\Component\EventDispatcher\Event $event = NULL) in /var/www/clients/client4965/web9958/web/vendor/symfony/event-dispatcher/LegacyEventDispatcherProxy.php on line 56“ while reading response header from upstream, client: 79.197.230.188, server: xxxx.xx, request: „GET /PaypalUnifiedExpressCheckout/expressCheckoutReturn/paymentId/PAYID-xxxx/token/EC-xxxxx/PayerID/xxx/basketId/express HTTP/2.0“, upstream: „fastcgi://unix:/var/lib/php5-fpm/web9958.sock:“, host: „xxxx.xx“, referrer: „xxx//xxxx.xx/flaches-gewuerzregal-wilma-geflammt“
2021/10/20 15:43:49 [error] 10158#10158: *228104 FastCGI sent in stderr: „PHP message: PHP Fatal error: Declaration of Symfony\Component\EventDispatcher\LegacyEventDispatcherProxy::dispatch($event) must be compatible with Symfony\Component\EventDispatcher\EventDispatcherInterface::dispatch($eventName, ?Symfony\Component\EventDispatcher\Event $event = NULL) in /var/www/clients/client4965/web9958/web/vendor/symfony/event-dispatcher/LegacyEventDispatcherProxy.php on line 56“ while reading response header from upstream, client: 79.197.230.188, server: xxxx.xx, request: „GET /PaypalUnifiedExpressCheckout/expressCheckoutReturn/paymentId/PAYID-xxxx/token/EC-xxxx/PayerID/xxx/basketId/express HTTP/2.0“, upstream: „fastcgi://unix:/var/lib/php5-fpm/web9958.sock:“, host: „xxxx.xx“, referrer: „xxx//xxxx.xx/grosses-obstkistenregal-tamme-geflammt“
2021/10/20 15:45:07 [error] 10151#10151: *228634 FastCGI sent in stderr: „PHP message: PHP Fatal error: Declaration of Symfony\Component\EventDispatcher\LegacyEventDispatcherProxy::dispatch($event) must be compatible with Symfony\Component\EventDispatcher\EventDispatcherInterface::dispatch($eventName, ?Symfony\Component\EventDispatcher\Event $event = NULL) in /var/www/clients/client4965/web9958/web/vendor/symfony/event-dispatcher/LegacyEventDispatcherProxy.php on line 56“ while reading response header from upstream, client: 79.197.230.188, server: xxxx.xx, request: „GET /PaypalUnifiedExpressCheckout/expressCheckoutReturn/paymentId/PAYID-xxxxx/token/EC-xxxx/PayerID/xxx/basketId/express HTTP/2.0“, upstream: „fastcgi://unix:/var/lib/php5-fpm/web9958.sock:“, host: „xxxx.xx“, referrer: „x//xxx.xx/grosses-obstkistenregal-tamme-geflammt“
Dies tritt nur bei Paypal Express auf.
Ich habe es jetzt deaktiviert und jetzt „läuft“ alles wieder, aber würde es gerne wieder aktivieren.
Hoffe mir kann wer helfen
