Hi zusammen, gerade eben seit langem mal wieder ein Stacktrace erhalten. exception 'Enlight\_Exception' with message 'BASKET-INSERT #01 No price acquired' in /home/www/p123341/html/shopware/engine/core/class/sBasket.php:2426 Stack trace: #0 /home/www/p123341/html/shopware/engine/core/class/sBasket.php(1478): sBasket-\>getPriceForAddArticle(Array) #1 /home/www/p123341/html/shopware/engine/Shopware/Controllers/Frontend/Checkout.php(319): sBasket-\>sAddArticle('G-50111-BLACKRE...', '1') #2 /home/www/p123341/html/shopware/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Frontend\_Checkout-\>addArticleAction() #3 /home/www/p123341/html/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('addArticleActio...') #4 /home/www/p123341/html/shopware/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 /home/www/p123341/html/shopware/engine/Shopware/Kernel.php(145): Enlight\_Controller\_Front-\>dispatch() #6 /home/www/p123341/html/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /home/www/p123341/html/shopware/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /home/www/p123341/html/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(428): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/www/p123341/html/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(328): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/www/p123341/html/shopware/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /home/www/p123341/html/shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #12 /home/www/p123341/html/shopware/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /home/www/p123341/html/shopware/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main} Hat jemand eine Idee, was das denn sein könnte? Allerbeste Greetz und Dankeschön vom Chris
Hi, das tritt bei Artikeln ohne Preis bzw. Preis = 0€ auf. Das unterstützt SW im Standard nicht. Hast du vll. so einen Artikel angelegt ggf. auch versehentlich? Daniel
Moinsen Daniel, habs eben auch rausgefunden, Danke! Es lag daran, dass ein falscher Staffelpreis übertragen worden ist, der da nicht hingehört und dieser Betrug 0, so dass man diesen nicht in den Korb legen konnte. Vielen Dank und viele Grüße, Chris
