Error Update von 6.5.6.1 auf 6.5.7.3 bricht ab: Column 'payment_method.technical_name' not found
beim Versuch SW6 von 6.5.6.1 auf 6.5.7.3 zu aktualisieren bricht der Prozess ab mit 500 Server Error und danach ist das Frontend nicht erreichbar (500 Error) das Backend geht noch.
Im php_error.log finden sich folgende Fehlermeldungen:
[2023-11-29T13:17:44.696700+00:00] request.CRITICAL: Uncaught PHP Exception Doctrine\DBAL\Exception\InvalidFieldNameException: "An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list'" at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php line 67 {"exception":"[object] (Doctrine\\DBAL\\Exception\\InvalidFieldNameException(code: 1054): An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php:67)\n[previous exception] [object] (Doctrine\\DBAL\\Driver\\PDO\\Exception(code: 1054): SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/PDO/Exception.php:28)\n[previous exception] [object] (PDOException(code: 42S22): SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/PDO/Statement.php:130)"} []
[2023-11-29T13:17:44.743113+00:00] php.CRITICAL: Uncaught Exception: Could not connect to database. Message from SQL Server: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' {"exception":"[object] (RuntimeException(code: 0): Could not connect to database. Message from SQL Server: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/shopware/core/HttpKernel.php:72)"} []
[2023-11-29T13:17:44.743347+00:00] request.CRITICAL: Uncaught PHP Exception RuntimeException: "Could not connect to database. Message from SQL Server: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list'" at /home/.../html/..._sw6/vendor/shopware/core/HttpKernel.php line 72 {"exception":"[object] (RuntimeException(code: 0): Could not connect to database. Message from SQL Server: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/shopware/core/HttpKernel.php:72)"} []
[2023-11-29T13:17:44.754411+00:00] php.CRITICAL: Uncaught Exception: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' {"exception":"[object] (Doctrine\\DBAL\\Exception\\InvalidFieldNameException(code: 1054): An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php:67)\n[previous exception] [object] (Doctrine\\DBAL\\Driver\\PDO\\Exception(code: 1054): SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/PDO/Exception.php:28)\n[previous exception] [object] (PDOException(code: 42S22): SQLSTATE[42S22]: Column not found: 1054 Unknown column 'payment_method.technical_name' in 'field list' at /home/.../html/..._sw6/vendor/doctrine/dbal/src/Driver/PDO/Statement.php:130)"} []
Hat jemand eine Idee was los ist und wie man das behebt?
Vielen Dank und Grüße,
Dany
Hi Dany,
vielleicht ists ein bisschen zu später aber das sollte dir helfen:
bin/console system:update:finish
Dadurch wird die Migration der Datenbank angestoßen wenn es beim Update Probleme gab.
Grüße
2 „Gefällt mir“
