Error in Backend and Orders not oppening after installation
Hello Everyone,
I am new to this forum and to shopware and I have tried twice to install shopware on my server and I keep getting this error. When I am running it on localhost it works fine.
Unable to load template snippet ‘backend/order/load.tpl|backend/order/payment_methods/controller/detail.js|backend/order/payment_methods/view/detail/payment_methods.js’ in Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace
#0 Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
 #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #5 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #6 Enlight/Event/EventManager.php(210): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #7 Enlight/Controller/Action.php(201): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #8 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('loadAction')
 #9 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #10 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch()
 #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #12 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #14 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #15 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #16 {main}
http://prntscr.com/a28zvh
I found on this forum that a few people have had a similar error but no solution. If anyone has had a similar situation and solved it if they can help me ? thanks
Hello,
perhaps some of the files are missing on your server. We recommend to upload the zip file directly on the server and use php or ssh to unzip this package on your server.
Moritz
Hi thanks for your replay, but that is how I uploaded the files both times and the problem still happens. Could it be some server setting or something ? I can’t think of what it could be…
