Directly import products to database
I am seeking to import products directly to the database, without the use of import tools or plugins. However, I am unsure of the required fields for each product. Could anyone kindly provide guidance on the necessary data to be entered? I am currently using Python and would like to write the code in Python. Therefore, I would appreciate an example of the data that needs to be generated or inserted, including tables, rows and so on.
It is better to use the API
If you still want to write directly to the database, you get all information from the API documentation.
