hi all,
does anybody knpw is there any alternativ plugin for delayin actions in flow builder except acris which is not working on 6.7.5 version
Thank You
hi all,
Thank You
The Shopware Store compatibility check indicates it should work.
I could not find any other plugin.
shopoware evolve plan does not provide delay/wait as action
we are waiting them to solve issue with serialization
Hi cab,
the issue was already fixed by ACRIS.
The plugin is compatible with all 6.7 versions.
If there is an issue with one of our plugins you can make a support question via the Shopware account. ACRIS always gives it’s best to provide you a great support and gives you a working solution soon.
Best regards,
Christoph
