Hallo auch ich habe Probleme mit dem Bundle Modul nach dem Update auf 4.1 und der Verwendung des neusten Bundle Moduls. Das Bundle Modul wirft folgenden Fehler aus
Unable to load template snippet ‘backend/article/store/bundle/variant.js’ in Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Event\_EventArgs)) #5 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Event\_EventArgs)) #6 Enlight/Event/EventManager.php(165): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Event\_EventArgs)) #7 Enlight/Controller/Action.php(191): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Array) #8 Enlight/Controller/Dispatcher/Default.php(521): Enlight\_Controller\_Action-\>dispatch('loadAction') #9 Enlight/Controller/Front.php(214): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight\_Controller\_Front-\>dispatch() #11 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(234): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 Shopware/Components/HttpCache/AppCache.php(99): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #17 shopware.php(83): Enlight\_Application-\>run() #18 {main}
Wer kennt das Problem und kann schnellstmöglich Hilfe anbieten. Support gibt es keinen, da ich die CE einsetze Gruß Ingo Hat nach dem x-ten Male installieren und deinstallieren doch noch geklappt.
