Brauche dringende Eure Hilfe!
Diesen Fehler nach Installation von Shopware 4.2.1 Fatal error: Uncaught exception ‚InvalidArgumentException‘ with message ‚[ERROR 3070] complex type ‚service‘: The content model is not determinist. (in file:////srv/www/max-handelshop.de/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 75, column 0) [ERROR 3070] complex type ‚argument‘: The content model is not determinist. (in file:////srv/www/max-handelshop.de/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 133, column 0) [ERROR 3070] complex type ‚call‘: The content model is not determinist. (in file:////srv/www/max-handelshop.de/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 146, column 0)‘ in /srv/www/max-handelshop.de/vendor/symfony/config/Symfony/Component/Config/Util/XmlUtils.php:90 Stack trace: #0 /srv/www/max-handelshop.de/vendor/symfony/dependency-injection/Symfony/Component/Dependenc in /srv/www/max-handelshop.de/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/XmlFileLoader.php on line 213 503 Service Unavailable Kann mir jemand Hinweis geben, warum dieses Fehler erscheint.
Hallo, ich bräuchte auch bitte dringend Hilfe und weiß nicht was ich tun kann und muss. Meldung nach Update wie beschrieben wenn ich das Backend aufrufen möchte: [quote] Fatal error: Uncaught exception ‘InvalidArgumentException’ with message ‘[ERROR 3070] complex type ‘service’: The content model is not determinist. (in file:////home/www/html/shop/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 75, column 0) [ERROR 3070] complex type ‘argument’: The content model is not determinist. (in file:////home/www/html/shop/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 133, column 0) [ERROR 3070] complex type ‘call’: The content model is not determinist. (in file:////home/www/html/shop/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/schema/dic/services/services-1.0.xsd - line 146, column 0)’ in /home/www/html/shop/vendor/symfony/config/Symfony/Component/Config/Util/XmlUtils.php:90 Stack trace: #0 /home/www/html/shop/vendor/symfony/dependency-injection/Symfony/Component/Dependenc in /home/www/html/shop/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Loader/XmlFileLoader.php on line 213 503 Service Unavailable[/quote] Danke für eure Unterstützung.
Die fast identische Fehlermeldung wird unter https://github.com/symfony/symfony/issues/7291 beschrieben. Die Lösung des Problems war die Version von libxml (2-2.6.26-2.1.21.el5_9.2.) downzugraden. Danach hat es bei denen funktioniert. Welche libxml Version verwendet euer Server/Hosting den aktuell? Gruß
