Backend Fehlercode
Hallo, ab und zu bekommen wir im Backend folgenden Fehler: Modul: Shopware.apps.Order Request-Pfad: /backend/Order/load/ HTTP Fehlermeldung: Service Unavailable HTTP Statuscode: 503 / GET
unable to write file /homepages/8/d419289969/htdocs/neutest05612/cache/templates/compile/backend_de_DE_7373c/eb/9b/c9/wrt53f47ad62a78c8.88848591 in Smarty/sysplugins/smarty_internal_write_file.php on line 48
Stack trace:
#0 Smarty/sysplugins/smarty\_internal\_template.php(201): Smarty\_Internal\_Write\_File::writeFile('/homepages/8/d4...', '<?php /* Smarty...', Object(Enlight_Template_Manager))
#1 Smarty/sysplugins/smarty_internal_templatebase.php(155): Smarty_Internal_Template->compileTemplateSource() #2 Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true) #3 cache/templates/compile/backend\_de\_DE\_7373c/0a/4a/8a/0a4a8acd798a2ab4be76bf4f3426595deb7101b8.snippet.2f3ba0e08e059572445c5701b348ac7390052483.php(80): Smarty\_Internal\_Template-\>getSubTemplate('backend/order/v...', 'local\_admins', 'backend\_de\_DE\_7...', NULL, NULL, Array, 0) #4 Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_53f47ad2705e20\_98755446(Object(Enlight\_Template\_Default)) #5 Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #6 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #7 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #8 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #9 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Event\_EventArgs)) #10 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Event\_EventArgs)) #11 Enlight/Event/EventManager.php(165): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Event\_EventArgs)) #12 Enlight/Controller/Action.php(191): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Array) #13 Enlight/Controller/Dispatcher/Default.php(521): Enlight\_Controller\_Action-\>dispatch('loadAction') #14 Enlight/Controller/Front.php(214): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #15 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight\_Controller\_Front-\>dispatch() #16 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #17 Shopware/Components/HttpCache/AppCache.php(234): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #18 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(230): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #19 Shopware/Components/HttpCache/AppCache.php(99): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #20 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #21 Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #22 shopware.php(83): Enlight\_Application-\>run() #23 {main}
Woran könnte das liegen?
