In case I try to host a module admin view, I receive the following view
This is due to the fact, that my iframe gets set to „display:none“
manifest.xml excerpt
<admin>
<module name="Keepoala"
parent="sw-order"
position="3"
source="http://localhost:8180"
<label>Keepoala</label>
<label lang="de-DE">Keepoala</label>
</module>
</admin>
Why is that the case? My website renders perfectly
To do this you need to confirm that your code has been loaded via a javascript snippet.
Here is an example of the javascript snippet.
AppTemplate/base.html.twig at master · shopwareLabs/AppTemplate · GitHub → window.parent.postMessage(‚sw-app-loaded‘, ‚*‘); must be called.
Also once again our documentation.
@SvenDenter , it works fine now. But would there be a way to set this timer > 5 seconds. Using a dev-environment my app builds in approx 6 seconds. Of course the app loads only 0.5 seconds after an optimized build, but during development I would like to check some things live. Maybe if shopware runs in debug mode (via dockware) this could be set higher?
