Shopware - Not able to show my page in My apps
I created Shopware App. I wanted to show my app in Iframe. But always showing „Whoops! You’ve moved too fast and lost orientation.“
This is my manifest.xml
<?xml version="1.0" encoding="UTF-8"?>
<manifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
          xsi:noNamespaceSchemaLocation="https://raw.githubusercontent.com/shopware/platform/master/src/Core/Framework/App/Manifest/Schema/manifest-1.0.xsd">
    <meta>
        <name>AppTemplate</name>
        <label>TwengApp</label>
        <label lang="de-DE">TwengApp</label>
        <description>Twenga Example App - Do not use in production</description>
        <description lang="de-DE">Twenga Beispiel App - Nicht im Produktivbetrieb verwenden</description>
        <author>Twenga</author>
        <copyright>(c) by Twenga</copyright>
        <version>1.2.3</version>
        <license>MIT</license>
    </meta>
    <setup>
        <registrationUrl>http://apptemplate.dev.localhost/register</registrationUrl> <!-- replace local url with real one -->
        <secret>01f17b06402f0a24e6d2b084a6d18a87</secret>
    </setup>
    <permissions>
        <read>product</read>
        <read>sales_channel</read>
    </permissions>
     <admin>
        <module name="home" source="http://apptemplate.dev.localhost/iframe/home">
            <label>Home</label>
            <label lang="de-DE">Home</label>
        </module>
    </admin>
</manifest>
And i’m using Symfony for my app, and this is my controller inside the app.
<?php
namespace App\Controller;
use App\Shop\ShopRepository;
use Shopware\AppBundle\Client\ClientFactoryInterface;
use Symfony\Bundle\FrameworkBundle\Controller\AbstractController;
use Symfony\Component\HttpFoundation\JsonResponse;
use Symfony\Component\HttpFoundation\Request;
use Symfony\Component\HttpFoundation\Response;
use Symfony\Component\Routing\Annotation\Route;
class HomeController extends AbstractController
    private ShopRepository $shopRepository;
    public function __construct(
        $this->shopRepository = $shopRepository;
        $this->clientFactory = $clientFactory;
     * Home Controller
    #[Route('/iframe/home', name: 'app_home')]
    public function index(Request $request): Response
        return $this->sign([
            'actionType' => 'openNewTab',
            'payload' => ["redirectUrl"=>"http://google.com"],
        ], $request->get('shop-id'));
    private function sign(array $content, string $shopId): JsonResponse
        $response = new JsonResponse($content);
        $shop = $this->shopRepository->getShopFromId($shopId);
        $hmac = \hash_hmac('sha256', $response->getContent(), $shop->getShopSecret());
        $response->headers->set('shopware-app-signature', $hmac);
        return $response;
And this is the error
And if i want to show html instead of json content in my iframe, what can i do for this ?
Please HELP !!!
Thank you
Did you add this in your loaded File?
function sendReadyState() {
window.parent.postMessage('sw-app-loaded', '*');
