404 Not found im Backend Artikelaufruf
Kann mir jemand sagen, was passiert ist? Versthe nur Bahnhof… Shopware 5.1.1 (Rev. 201510221322) - Backend © shopware AG iframe { border: 0 none !important; width: 100%; height: 100%; } #nav ul { top: 26px !important } #header li.main { height: 28px !important } .deprecated { color: #fff; font-size: 11px; font-weight: 700; text-align: center } Ext.editorLang = ‘de’; Ext.shopwareRevision = ‘201510221322’; var userName = ‘Jens Rabenseifner’, maxParameterLength = ‘0’; Ext.define(‘Shopware.app.Application’, { extend: ‘Ext.app.Application’, name: ‘Shopware’, singleton: true, autoCreateViewport: false, requires: [‘Shopware.container.Viewport’], baseComponents: { ‘Shopware.container.Viewport’: false, ‘Shopware.apps.Index.view.Menu’: false, ‘Shopware.apps.Index.view.Footer’: false }, viewport: null, launch: function() { var me = this, preloader = Ext.create(‘Shopware.component.Preloader’).bindEvents(Shopware.app.Application), errorReporter = Ext.create(‘Shopware.global.ErrorReporter’).bindEvents(Shopware.app.Application) /** * Activates the Ext.fx.Anim class globally and * drives the animations our CSS 3 if supported. */ Ext.enableFx = true; this.addEvents(‘baseComponentsReady’, ‘subAppLoaded’); // Disable currency sign Ext.apply(Ext.util.Format, { currencySign: ‘’ }); // Fix default date format Ext.Date.defaultFormat = Ext.util.Format.dateFormat; this.callParent(arguments); this.addSubApplication({ name: “Shopware.apps.Index”, controller: “customizing”, params: , localizedName: ‘Shopware’, firstRunWizardEnabled: 0, sbpLogin: 0, updateWizardStarted: 1 }); // Start preloading the icon sets me.iconPreloader = Ext.create(‘Shopware.component.IconPreloader’, { loadPath: “http://kalimbula.de/themes/Backend/ExtJs/backend/_resources/resources/css” }); }, /** * Checks if all base components are loaded and rendered. * If truthy the preloader will be triggered. * * @param cmp - Component which calls the method * @return void */ baseComponentIsReady: function(cmp) { var me = this, allReady = true; me.baseComponents[cmp.$className] = true; Ext.iterate(me.baseComponents, function(index, item) { if(!item) { allReady = false; return false; } }); if(allReady) { window.setTimeout(function() { me.fireEvent(‘baseComponentsReady’, me); }, 1000); } } }); /** Basic loader configuration */ Ext.Loader.setConfig({ enabled: true, disableCaching: true, disableCachingParam: ‘no-cache’, disableCachingValue: ‘1451576472+1+1’ }); Ext.Loader.setPath(‘Shopware.apps’, ‘/backend’, ‘?file=app’); Ext.onReady(function() { var timeField = Ext.create(‘Ext.form.field.Time’); this.timeFormat = timeField.format; }); Sieht so aus, als hinge das mit dem Custom Product Plugin von Shopware zusammen. Nach dem letzten Update kam diese Meldung. Da ich dieses Plugin nun nicht mehr benötige, habe ich es deinstalliert. Cache geleert. Und die Meldung kommt nicht mehr…
