Ich habe zahlreiche Error-Mails erhalten. Liegt das Problem bei HTTP-Cache? [2014-10-12 11:48:59] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Action “Frontend_Checkout_pOSTAction” not found failure’ in /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Enlight_Controller_Action->__call(‘pOSTAction’, Array) #1 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->pOSTAction() #2 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘pOSTAction’) #3 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #4 /var/www/vhosts/domain.tld/httpdocs/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #5 /var/www/vhosts/domain.tld/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /var/www/vhosts/domain.tld/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /var/www/vhosts/domain.tld/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /var/www/vhosts/domain.tld/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /var/www/vhosts/domain.tld/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/vhosts/domain.tld/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/www/vhosts/domain.tld/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/vhosts/domain.tld/httpdocs/shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} Bitte um Hilfe. mfg Vincent
Das sind meistens ungültige Seitenaufrufe von Bots. Das kannst du auch im Demoshop provozieren, wenn du eine Seite mit falschen Parametern aufrufst: http://www.shopwaredemo.de/checkout/pOST Viele Grüße
