wir sind down nach update bitten um Hilfe
Hallo , wir bekommen folgende Fehlermeldung nach update von 3 auf 4 könnt ihr uns da helfen ? QLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‚)‘ at line 1 in Doctrine/DBAL/Connection.php on line 630 Stack trace: #0 Doctrine/DBAL/Connection.php(630): PDOStatement->execute(Array) #1 Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(46): Doctrine\DBAL\Connection->executeQuery(‚SELECT s0_.id A…‘, Array, Array, NULL) #2 Doctrine/ORM/Query.php(260): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 Doctrine/ORM/AbstractQuery.php(595): Doctrine\ORM\Query->_doExecute() #4 Doctrine/ORM/AbstractQuery.php(432): Doctrine\ORM\AbstractQuery->execute(Array, 2) #5 Shopware/Controllers/Widgets/Emotion.php(365): Doctrine\ORM\AbstractQuery->getArrayResult() #6 Shopware/Controllers/Widgets/Emotion.php(147): Shopware_Controllers_Widgets_Emotion->getManufacturerSlider(Array, 3, Array) #7 Enlight/Controller/Action.php(135): Shopware_Controllers_Widgets_Emotion->indexAction() #8 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‚indexAction‘) #9 Enlight/Template/Plugins/function.action.php(94): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 cache/templates/compile/frontend_emotion_orange_de_DE_1/05/48/b6/0548b6775a8bc2c728c3f95e474a86333a9d5d19.snippet.index.tpl.php(448): smarty_function_action(Array, Object(Enlight_Template_Default)) #11 Smarty/sysplugins/smarty_internal_templatebase.php(180): content_50fe88210bf523_45026897(Object(Enlight_Template_Default)) #12 Enlight/View/Default.php(273): Smarty_Internal_TemplateBase->fetch() #13 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #14 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #15 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #16 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #17 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Event_EventArgs)) #18 Enlight/Event/EventManager.php(156): Enlight_Event_Handler_Default->execute(Object(Enlight_Event_EventArgs)) #19 Enlight/Controller/Action.php(147): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Array) #20 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‚indexAction‘) #21 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #22 Shopware/Bootstrap.php(79): Enlight_Controller_Front->dispatch() #23 Enlight/Application.php(192): Shopware_Bootstrap->run() #24 shopware.php(74): Enlight_Application->run() #25 {main}
evtl hilfts installation-einstieg-f54/sql-fehler-nach-update-in-verb-mit-einkaufswelt-t9925.html
danke hab ich gefunden :slight_smile: Hat geholfen :slight_smile:
