Wesentliche Merkmale laden nicht
Kennt jemand das Phänomen, dass plötzlich und nur die „wesentlichen Merkmale“ im Backend nicht mehr aufrufbar sind?
Der dev.log wirft aus
[2021-03-21 13:37:02] request.INFO: Matched route "api.product_feature_set.search". {"route":"api.product_feature_set.search","route_parameters":{"_route":"api.product_feature_set.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"product-feature-set","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/product-feature-set","method":"POST"} []
[2021-03-21 13:37:02] request.INFO: Matched route "api.language.search". {"route":"api.language.search","route_parameters":{"_route":"api.language.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"language","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/language","method":"POST"} []
[2021-03-21 13:37:07] php.INFO: User Deprecated: The "Symfony\Component\Debug\DebugClassLoader" class is deprecated since Symfony 4.4, use "Symfony\Component\ErrorHandler\DebugClassLoader" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\Debug\\DebugClassLoader\" class is deprecated since Symfony 4.4, use \"Symfony\\Component\\ErrorHandler\\DebugClassLoader\" instead. at /usr/www/users/xxxxxxxx/shop/vendor/symfony/debug/DebugClassLoader.php:16)"} []
[2021-03-21 13:37:07] request.INFO: Matched route "api.message_queue_stats.search". {"route":"api.message_queue_stats.search","route_parameters":{"_route":"api.message_queue_stats.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"message-queue-stats","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/message-queue-stats","method":"POST"} []
[2021-03-21 13:37:08] php.INFO: User Deprecated: The "Symfony\Component\Debug\DebugClassLoader" class is deprecated since Symfony 4.4, use "Symfony\Component\ErrorHandler\DebugClassLoader" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\Debug\\DebugClassLoader\" class is deprecated since Symfony 4.4, use \"Symfony\\Component\\ErrorHandler\\DebugClassLoader\" instead. at /usr/www/users/xxxxxxxx/shop/vendor/symfony/debug/DebugClassLoader.php:16)"} []
[2021-03-21 13:37:08] request.INFO: Matched route "api.message_queue_stats.search". {"route":"api.message_queue_stats.search","route_parameters":{"_route":"api.message_queue_stats.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"message-queue-stats","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/message-queue-stats","method":"POST"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.custom_field_set.search". {"route":"api.custom_field_set.search","route_parameters":{"_route":"api.custom_field_set.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"custom-field-set","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/custom-field-set","method":"POST"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.product.search". {"route":"api.product.search","route_parameters":{"_route":"api.product.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"product","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/product","method":"POST"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.app_system.action_buttons". {"route":"api.app_system.action_buttons","route_parameters":{"_route":"api.app_system.action_buttons","_controller":"Shopware\\Core\\Framework\\App\\Api\\AppActionController::getActionsPerView","version":"2","entity":"product","view":"detail"},"request_uri":"https://www.xxxxxxxxtrend.de/api/v2/app-system/action-button/product/detail","method":"GET"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.language.search". {"route":"api.language.search","route_parameters":{"_route":"api.language.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"language","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/language","method":"POST"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.media_folder.search". {"route":"api.media_folder.search","route_parameters":{"_route":"api.media_folder.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"media-folder","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/media-folder","method":"POST"} []
[2021-03-21 13:39:34] php.INFO: User Deprecated: The "Symfony\Component\Debug\DebugClassLoader" class is deprecated since Symfony 4.4, use "Symfony\Component\ErrorHandler\DebugClassLoader" instead. {"exception":"[object] (ErrorException(code: 0): User Deprecated: The \"Symfony\\Component\\Debug\\DebugClassLoader\" class is deprecated since Symfony 4.4, use \"Symfony\\Component\\ErrorHandler\\DebugClassLoader\" instead. at /usr/www/users/xxxxxxxx/shop/vendor/symfony/debug/DebugClassLoader.php:16)"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.product_feature_set.search". {"route":"api.product_feature_set.search","route_parameters":{"_route":"api.product_feature_set.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"product-feature-set","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/product-feature-set","method":"POST"} []
[2021-03-21 13:39:34] request.INFO: Matched route "api.media.search". {"route":"api.media.search","route_parameters":{"_route":"api.media.search","_controller":"Shopware\\Core\\Framework\\Api\\Controller\\ApiController::search","entityName":"media","version":"3","path":""},"request_uri":"https://www.xxxxxxxxtrend.de/api/v3/search/media","method":"POST"} []
Hallo @markb !
Ja, das Problem habe ich aktuell auch und ich finde bisher keine Lösung.
Alle Caches und Index sind neu aufgebaut aber es gibt über Eigenschaften → Wesentliche Merkmale nur die Ladeanzeige und man kommt nicht auf die bereits angelegten wesentliche Merkmale. :thinking:
Einzig das „Neu erstellen“ ist möglich aber danach nicht über „Wesentliche Merkmale“ aufrufbar, weil Ladeschleife. Ich habe das in Firefox und Chrome getestet, jeweils auch mit geleerten Browsercahes.
Hast Du vielleicht schon eine Lösung dafür gefunden?
Ich nutze Shopware 6 Community Version 6.4.2.1
Ich bin mir nicht mehr sicher. Ruf die mal die Datenbanktabellen auf. Ich glaube hier war erkennbar, was nicht stimmt.
Danke, der Fehler liegt in der SQL Tabelle „product_feature_set“
Dort habe ich die zwei von mir selbst erzeugten Einträge für die wesentlichen Merkmale wieder entfernt und nur das Standard-Template belassen (automatisch erzeugt am Installationsdatum). Cache löschen und aufwärmen und die Backend-Seite Einstellungen → Wesentliche Merkmale lädt wieder.
Das erklärt natürlich nicht, warum der gesamte Seitenaufruf ohne Fehlermeldung nicht funktioniert, nur weil man eigene Tabelleneinträge hat.
Hinter der schönen Shopware Fassade steckt doch noch jede Menge 90er Jahre UX. Mit Nutzerfreundlichkeit hat das jedenfalls nichts zu tun.
