Was bedeutet folgende Fehlermeldung, die ich per eMail vom System bekomme?: [quote][2014-02-12 02:08:31] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Action “Frontend_Blog_naehmaschinenTippsAction” not found failure’ in /www/htdocs/w010be7f/naehmaschinen/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /www/htdocs/w010be7f/naehmaschinen/engine/Library/Enlight/Controller/Action.php(159): Enlight_Controller_Action->__call(‘naehmaschinenTi…’, Array) #1 /www/htdocs/w010be7f/naehmaschinen/engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersFrontendBlogProxy->naehmaschinenTippsAction() #2 /www/htdocs/w010be7f/naehmaschinen/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘naehmaschinenTi…’) #3 /www/htdocs/w010be7f/naehmaschinen/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #4 /www/htdocs/w010be7f/naehmaschinen/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #5 /www/htdocs/w010be7f/naehmaschinen/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /www/htdocs/w010be7f/naehmaschinen/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /www/htdocs/w010be7f/naehmaschinen/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /www/htdocs/w010be7f/naehmaschinen/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w010be7f/naehmaschinen/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w010be7f/naehmaschinen/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /www/htdocs/w010be7f/naehmaschinen/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /www/htdocs/w010be7f/naehmaschinen/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} [/quote]
Hi, das bedeutet, dass “http://xxxx/blog/naehmaschinentipps/” aufgerufen wird statt “http://xxx/naehmaschinentipps/”. Wenn ich mich richtig erinnere, kann das teilweise passieren, wenn man bspw. eine Kategorie angelegt hat, die “blog” heißt, dann können SEO-Routen entstehen, die “blog/naehmaschinentipps” lauten - weil es einen Controller “blog” gibt, geht SW dann davon aus, dass der gemeint ist und leitet nicht auf die Kategorie um. Weil der Controller keine solche “Action” hat, gibt es einen Fehler. Kann das sein, dass die Kategorie bei euch in der Vergangenheit mal “blog” hießt und dann umbenannt wurde? Vll. hat das irgendeine SuMa falsch indexiert. Auf eurer Seite selbst sieht ja alles richtig aus, von daher würde ich zZt nicht davon ausgehen, dass man aus SW heraus auf der Seite landet. lG Daniel
Hallo Daniel, [quote=„Daniel Nögel“]Hi, das bedeutet, dass „http://xxxx/blog/naehmaschinentipps/“ aufgerufen wird statt „http://xxx/naehmaschinentipps/“. … Kann das sein, dass die Kategorie bei euch in der Vergangenheit mal „blog“ hießt und dann umbenannt wurde? Vll. hat das irgendeine SuMa falsch indexiert. Auf eurer Seite selbst sieht ja alles richtig aus, von daher würde ich zZt nicht davon ausgehen, dass man aus SW heraus auf der Seite landet. lG Daniel[/quote] Das kann natürlich sein, dass man den Blog ursprünglich ‚blog‘ nannte. Ich weiß das nicht mehr. Was soll ich tun?
Hallo, ich hatte da schon in deinem anderen Post drauf geantwortet. Das sollte auch bei euch keinerlei funktionelle Auswirkungen haben. Sebastian
Das bedeutet: Ich schalte am besten die Logs-eMail-Benachrichtigung ab, oder?
[quote=“jox”]Das bedeutet: Ich schalte am besten die Logs-eMail-Benachrichtigung ab, oder?[/quote] Bin mir nicht sicher, denn es sind ja Fehlermeldungen die man eigentlich beheben sollte. Bei mir kommen aktuell folgende Meldungen per E-Mail: Stack trace: #0 /luphharg/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(211): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>checkAuth() #1 /luphharg/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onPreDispatchBackend(Object(Enlight\_Event\_EventArgs)) #2 /luphharg/engine/Library/Enlight/Event/EventManager.php(156): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #3 /luphharg/engine/Library/Enlight/Controller/Action.php(122): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Array) #4 /luphharg/engine/Library/Enlight/Controller/Dispatcher/Default.php(521): Enlight\_Controller\_Action-\>dispatch('createLogAction') #5 /luphharg/engine/Library/Enlight/Controller/Front.php(214): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #6 /luphharg/engine/Shopware/Bootstrap.php(79): Enlight\_Controller\_Front-\>dispatch() #7 /luphharg/engine/Library/Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #8 /luphharg/shopware.php(74): Enlight\_Application-\>run() #9 {main} Und ich habe keine Ahnung welche Rechte nicht passen. Generell finde ich die Rechteverwaltung bei Shopware sowieso nicht durchsichtig. Da fehlt mir eine klare Beschreibung.
