Hallo zusammen, wenn im Shop die URL domain.de/blog/wp-admin/ aufgerufen wird, gibt es einen Fehler: [quote] ERROR Message: exception ‚Enlight_Controller_Exception‘ with message ‚Action „Frontend_Blog_wpAdminAction“ not found failure‘ in /…/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /…/engine/Library/Enlight/Controller/Action.php(159): Enlight_Controller_Action->__call(‚wpAdminAction‘, Array) #1 /…/engine/Library/Enlight/Controller/Action.php(159): Shopware_ProxiesStaging_ShopwareControllersFrontendBlogProxy->wpAdminAction() #2 /…/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‚wpAdminAction‘) #3 /…/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #4 /…/engine/Shopware/Kernel.php(145): Enlight_Controller_Front->dispatch() #5 /…/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /…/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /…/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(428): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /…/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(328): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /…/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /…/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /…/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /…/shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} Time: 2015-08-02T06:15:56.083060+0200 Channel: core request: { „uri“: „/blog/wp-admin/“, „method“: „GET“, „query“: { „controller“: „blog“, „action“: „wp-admin“ }, „post“: } session: { „sessionId“: „c64711b8ab50c81188b7f30c24e4fcddb0b9c45d“, „Bot“: false, „sOutputNet“: false } shopId: 1 shopName: Hauptshop Deutsch [/quote] Warum läuft Shopware bei der Action „wp-admin“ in einen Fehler und warum leitet es nicht auf die Startseite weiter, wie bei anderen Seiten auch, die gar nicht existieren? Hat einer eine Idee?
Bin mir nicht ganz sicher, aber vermutlich weil es den Blog-Controller gibt und dieser dann versucht alles zu verarbeiten was mit /blog/ beginnt.
Der Fehler ist in diesem Beitrag der FAQ erklärt: sonstiges-f58/faq-haufig-gestellte-fragen-t24425.html#p106942 Prinzipiell kannst du den gleichen Fehler mit vielen, ungültigen URLs aufrufen. Zwei Beispiele: /checkout/bla /blog/blablub … Viele Grüße
