Vagrant and https redirection.
Hi, everyone! I’m trying to set up my Shopware project on VirtualBox and Vagrant. And I have the https redirection error. Since I can’t access the admin panel, I used the database dump where the SSL configurations are switched off. But it didn’t help(   The most interesting is that on another machine (with Linux) this problem was solved with editing of configurations in the admin panel. But it didn’t work for me. Any ideas why does it happen?
Thanks in advance.
Hi Nataly,
did you have a look into our documentation about setting up shopware on VagrantVM?
https://docs.shopware.com/en/shopware-platform-dev-en/getting-started/system-installation-guides/vagrant?category=shopware-platform-dev-en/getting-started/system-installation-guides
I just had a look into the installation process, that worked perfectly fine for me.
Kind regards,
Tim
