Help me plase. I am trying to install Shopware 6 by Vagrant and VirtualBox and it seems that everything is ok but it is not. After installation while I am trying to open 192.168.33.10 in my browser I can only see this:
What I have done so far:
- I have Vagrant installed
I have Oracle VirtualBox installed
I have Oracle VirtualBox Extension Pack installed
Please help me with this. I was destroying and rebuilding installation few times while I was adding some necessary plugins mentioned in web but nothing helped me.
While “vagrant reload” I receive something like that in command line:
Vagrant was unable to mount VirtualBox shared folders. This is usually
because the filesystem “vboxsf” is not available. This filesystem is
made available via the VirtualBox Guest Additions and kernel module.
Please verify that these guest additions are properly installed in the
guest. This is not a bug in Vagrant and is usually caused by a faulty
Vagrant box. For context, the command attempted was:
mount -t vboxsf -o uid=1000,gid=1000 vagrant /vagrant
The error output from the command was:
/sbin/mount.vboxsf: mounting failed with the error: No such device
