build funktioniert nicht nach update:
–=[1]=–
$ bin/build.sh
($ bin/build-storefront.sh)
+++ dirname – bin/build.sh
++ cd -P – bin
++ pwd -P
- BIN_DIR=/var/www/html/bin
++ dirname /var/www/html/bin - export PROJECT_ROOT=/var/www/html
- PROJECT_ROOT=/var/www/html
- composer install -d /var/www/html --no-interaction --optimize-autoloader --no-suggest
You are using the deprecated option „–no-suggest“. It has no effect and will break in Composer 3.
[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:prepare
Run Update preparations
Installing dependencies from lock file (including require-dev)
Verifying lock file contents can be installed on current platform.
Nothing to install, update or remove
Package symfony/inflector is abandoned, you should avoid using it. Use useEnglishInflectorfrom the String component instead instead.
Package fzaninotto/faker is abandoned, you should avoid using it. No replacement was suggested.
Package sebastian/resource-operations is abandoned, you should avoid using it. No replacement was suggested.
Generating optimized autoload files
composer/package-versions-deprecated: Generating version class…
composer/package-versions-deprecated: …done generating version class
121 packages you are using are looking for funding.
Use thecomposer fundcommand to find out more!
Warning: The lock file is not up to date with the latest changes in composer.json. You may be getting outdated dependencies. It is recommended that you runcomposer updateorcomposer update <package name>.
Generating autoload files
26 packages you are using are looking for funding.
16 packages you are using are looking for funding.
[ ! -f install.lock ] || $PHP_BINARY bin/console system:update:finish
Run Post Update
Get collection for identifier: „core“
migrate Migrations
0 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]
Action Number of migrations
Migrated 0 out of 0
all migrations for identifier: „core“ executed
In DatabaseConfigLoader.php line 206:
Notice: Undefined index: type
–=[2]=–
$ bin/console system:update:finish
Run Post Update
migrate Migrations
0 [=░░░░░░░░░░░░░░░░░░░░░░░░░░░]
Migrated 0 out of 0
