Fehler beim composer update: Required package "shopware/core" is not present in the lock file
Wenn ich composer update in der Console eingebe erhalte ich folgende Fehlermeldung:
> [ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:prepare
Run Update preparations
Loading composer repositories with package information
Updating dependencies
Nothing to modify in lock file
Installing dependencies from lock file (including require-dev)
Nothing to install, update or remove
Package sensio/framework-extra-bundle is abandoned, you should avoid using it. Use Symfony instead.
Package shopware/recovery is abandoned, you should avoid using it. No replacement was suggested.
Package symfony/inflector is abandoned, you should avoid using it. Use EnglishInflector from the String component instead.
Package true/punycode is abandoned, you should avoid using it. No replacement was suggested.
Generating optimized autoload files
130 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
Verifying lock file contents can be installed on current platform.
Warning: The lock file is not up to date with the latest changes in composer.json. You may be getting outdated dependencies. It is recommended that you run `composer update` or `composer update <package name>`.
- Required package "shopware/core" is not present in the lock file.
This usually happens when composer files are incorrectly merged or the composer.json file is manually edited.
Read more about correctly resolving merge conflicts https://getcomposer.org/doc/articles/resolving-merge-conflicts.md
and prefer using the "require" command over editing the composer.json file directly https://getcomposer.org/doc/03-cli.md#require-r
Script @composer install --working-dir vendor/shopware/recovery --no-interaction --no-scripts handling the post-update-cmd event returned with error code 4
composer update --lock habe ich schon durchgeführt, behebt den Fehler aber nicht.
Composer version 2.6.3
Hat jemand eine Ahnung, wie man das Problem beheben kann?
composer.json sieht bei mir so aus:
    "name": "shopware/production",
    "type": "project",
    "license": "MIT",
    "config": {
        "optimize-autoloader": true,
        "platform": {
            "php": "8.2.10"
        "sort-packages": true,
        "allow-plugins": {
            "composer/package-versions-deprecated": true
    "prefer-stable": true,
    "minimum-stability": "stable",
    "scripts": {
        "pre-install-cmd": [
            "[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:prepare"
        "pre-update-cmd": [
        "post-install-cmd": [
            "@composer install --working-dir vendor/shopware/recovery --no-interaction --no-scripts",
            "@composer install --working-dir=vendor/shopware/recovery/Common --no-interaction --optimize-autoloader --no-suggest",
            "[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:finish"
        "post-update-cmd": [
    "autoload": {
        "psr-4": {
            "Shopware\\Production\\": "src/"
    "repositories": [
            "type": "path",
            "url": "custom/plugins/*/packages/*",
            "options": {
                "symlink": true
            "type": "path",
            "url": "custom/static-plugins/*",
            "options": {
                "symlink": true
    "require": {
        "php": "^7.4.3 || ^8.2",
        "composer-runtime-api": "^2.0",
        "shopware/administration": "~v6.4.20.2",
        "shopware/core": "~v6.4.20.2",
        "shopware/elasticsearch": "~v6.4.20.2",
        "shopware/recovery": "~v6.4.20.2",
        "shopware/storefront": "~v6.4.20.2"
    "require-dev": {
        "ext-openssl": "*",
        "ext-tokenizer": "*",
        "ext-xmlwriter": "*",
        "defuse/php-encryption": "~2.2.1",
        "dms/phpunit-arraysubset-asserts": "^0.2.1",
        "fakerphp/faker": "~1.14.1",
        "johnkary/phpunit-speedtrap": "~3.3.0",
        "league/flysystem-memory": "~1.0.2",
        "maltyxx/images-generator": "~1.0.0",
        "mbezhanov/faker-provider-collection": "~2.0.1",
        "nikic/php-parser": "~4.13.2",
        "opis/json-schema": "~1.0.19",
        "phpunit/php-code-coverage": "~9.2.14",
        "phpunit/phpunit": "~9.5.17",
        "smalot/pdfparser": "~0.14.0",
        "symfony/browser-kit": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/dependency-injection": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/css-selector": "^5.3",
        "symfony/dom-crawler": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/phpunit-bridge": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/stopwatch": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/var-dumper": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0",
        "symfony/web-profiler-bundle": "~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0"
Sollte jemand auch das Problem haben, dieser Hinweis hier hat es gelöst: php - Composer-"bug" in shopware project - Stack Overflow
