Update auf 6.6.0.2
Oder anders ausgedrückt:
th
ebenfalls ein error
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.000 seconds
Your requirements could not be resolved to an installable set of packages.
  Problem 1
    - Root composer.json requires shopware/core 6.6.0.2 -> satisfiable by shopware/core[v6.6.0.2].
    - shopware/core v6.6.0.2 requires symfony/stopwatch ~7.0.0 -> found symfony/stopwatch[v7.0.0, v7.0.3] but it conflicts with your root composer.json require (^5.0|^6.0).
  Problem 2
    - shopware/storefront v6.6.0.2 requires shopware/core v6.6.0.2 -> satisfiable by shopware/core[v6.6.0.2].
    - Root composer.json requires shopware/storefront 6.6.0.2 -> satisfiable by shopware/storefront[v6.6.0.2].
Use the option --with-all-dependencies (-W) to allow upgrades, downgrades and removals for packages currently locked to specific versions.
von 6.5.8.7 auf 6.6.0.2
Das Update bricht ohne echte Fehlermeldung ab. Nachfolgend das Ende der log.txt. Im ganzen log ist keine Fehlermeldung enthalten.
  Enabling the package as a Symfony bundle
    Copying files from recipe
      Created "./config/packages/dev/monolog.yaml"
      Created "./config/packages/prod/deprecations.yaml"
      Created "./config/packages/prod/monolog.yaml"
      Created "./config/packages/test/monolog.yaml"
  - Configuring symfony/routing (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/translation (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/twig-bundle (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/validator (>=7.0): From github.com/symfony/recipes:main
      Created "./config/packages/validator.yaml"
  - Configuring phpunit/phpunit (>=9.6): From github.com/symfony/recipes:main
      Created "./.env.test"
      Created "./phpunit.xml.dist"
      Created "./tests/bootstrap.php"
    Adding entries to .gitignore
  - Configuring symfony/web-profiler-bundle (>=6.1): From github.com/symfony/recipes:main
      Created "./config/packages/web_profiler.yaml"
      Created "./config/routes/web_profiler.yaml"
 Files have been reset to the latest version of the recipe.
  * Use git diff to inspect the changes.
    Not all of the changes will be relevant to your app: you now
    need to selectively add or revert them using e.g. a combination
    of git add -p and git checkout -p
  * Use git checkout . to revert the changes.
    New (untracked) files can be inspected using git clean --dry-run
    Add the new files you want to keep using git add
    then delete the rest using git clean --force
Könntet ihr mal die composer.json posten?
    "name": "shopware/production",
    "type": "project",
    "license": "MIT",
    "config": {
        "optimize-autoloader": true,
        "sort-packages": true,
        "allow-plugins": {
            "composer/package-versions-deprecated": true,
            "symfony/flex": true,
            "symfony/runtime": true
    "prefer-stable": true,
    "scripts": {
        "auto-scripts": {
            "assets:install": "symfony-cmd"
        "post-install-cmd": [
            "@auto-scripts"
        "post-update-cmd": [
            "@auto-scripts"
    "autoload": {
        "psr-4": {
            "Shopware\\Production\\": "src/"
    "repositories": [
            "type": "path",
            "url": "custom/plugins/*/packages/*",
            "options": {
                "symlink": true
            "type": "path",
            "url": "custom/static-plugins/*",
            "options": {
                "symlink": true
            "type": "path",
            "url": "custom/plugins/*",
            "options": {
                "symlink": true
    "require": {
        "php": "^7.4.3 || ^8.0",
        "composer-runtime-api": "^2.0",
        "payone-gmbh/shopware-6": "5.0.2",
        "shopware/administration": "6.5.8.7",
        "shopware/core": "6.5.8.7",
        "shopware/elasticsearch": "6.5.8.7",
        "shopware/storefront": "6.5.8.7",
        "swag/amazon-pay": "9.0.0",
        "symfony/flex": "^2"
    "require-dev": {
        "shopware/dev-tools": "*"
    "extra": {
        "symfony": {
            "allow-contrib": true,
            "endpoint": [
                "https://raw.githubusercontent.com/shopware/recipes/flex/main/index.json",
                "flex://defaults"
Hat sich bei mir erledigt. Ich musste noch Amazon Pay aktualisieren, obwohl es deaktiviert war.
