Hallo zusammen.
Ich versuche gerade, meine 6.5.5.2 Installation auf 6.6.1.1 hochzuziehen.
Dabei bin ich im ersten Schritt auf die höchste 6.5er Version gegangen (6.5.8.9) - hat geklappt.
Anschließend wollte ich dann hoch auf 6.6.0.0, das klappt dann aber nicht mehr. Folgender Fehleroutput:
Protokoll
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.004 seconds
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Root composer.json requires shopware/administration 6.6.0.0 -> satisfiable by shopware/administration[v6.6.0.0].
- symfony/security-bundle[v6.4.0, v6.4.2, v6.4.3, v6.4.4, v6.4.5, v6.4.6] require symfony/http-kernel ^6.2 -> satisfiable by symfony/http-kernel[v6.2.0, v6.2.1, v6.2.2, v6.2.3, v6.2.4, v6.2.5, v6.2.6, v6.2.7, v6.2.8, v6.2.9, v6.2.10, v6.2.11, v6.2.12, v6.2.13, v6.2.14, v6.3.0, v6.3.1, v6.3.2, v6.3.3, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.9, v6.3.10, v6.3.11, v6.3.12, v6.4.0, v6.4.1, v6.4.2, v6.4.3, v6.4.4, v6.4.5, v6.4.6].
- symfony/security-bundle[v6.3.0, v6.3.1, v6.3.2, v6.3.3, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.11, v6.3.12] require symfony/http-foundation ^6.2 -> satisfiable by symfony/http-foundation[v6.2.0, v6.2.1, v6.2.2, v6.2.5, v6.2.6, v6.2.7, v6.2.8, v6.2.10, v6.2.11, v6.2.12, v6.2.13, v6.3.0, v6.3.1, v6.3.2, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.9, v6.3.11, v6.3.12, v6.4.0, v6.4.2, v6.4.3, v6.4.4].
- You can only install one version of a package, so only one of these can be installed: symfony/http-kernel[v4.4.0, v4.4.1, v4.4.2, v4.4.3, v4.4.4, v4.4.5, v4.4.6, v4.4.7, v4.4.8, v4.4.9, v4.4.10, v4.4.11, v4.4.12, v4.4.13, v4.4.14, v4.4.15, v4.4.16, v4.4.17, v4.4.18, v4.4.19, v4.4.20, v4.4.21, v4.4.22, v4.4.23, v4.4.24, v4.4.25, v4.4.26, v4.4.27, v4.4.28, v4.4.29, v4.4.30, v4.4.31, v4.4.32, v4.4.33, v4.4.34, v4.4.35, v4.4.36, v4.4.37, v4.4.38, v4.4.39, v4.4.40, v4.4.41, v4.4.42, v4.4.43, v4.4.44, v4.4.45, v4.4.46, v4.4.47, v4.4.48, v4.4.49, v4.4.50, v4.4.51, v5.0.0, v5.0.1, v5.0.2, v5.0.3, v5.0.4, v5.0.5, v5.0.6, v5.0.7, v5.0.8, v5.0.9, v5.0.10, v5.0.11, v5.1.0, v5.1.1, v5.1.2, v5.1.3, v5.1.4, v5.1.5, v5.1.6, v5.1.7, v5.1.8, v5.1.9, v5.1.10, v5.1.11, v5.2.0, v5.2.1, v5.2.2, v5.2.3, v5.2.4, v5.2.5, v5.2.6, v5.2.7, v5.2.8, v5.2.9, v5.2.10, v5.2.11, v5.2.12, v5.2.13, v5.2.14, v5.3.0, v5.3.1, v5.3.2, v5.3.3, v5.3.4, v5.3.5, v5.3.6, v5.3.7, v5.3.8, v5.3.9, v5.3.10, v5.3.11, v5.3.12, v5.3.13, v5.3.14, v5.3.15, v5.3.16, v5.4.0, v5.4.1, v5.4.2, v5.4.3, v5.4.4, v5.4.5, v5.4.6, v5.4.7, v5.4.8, v5.4.9, v5.4.10, v5.4.11, v5.4.12, v5.4.13, v5.4.14, v5.4.15, v5.4.16, v5.4.17, v5.4.18, v5.4.19, v5.4.20, v5.4.21, v5.4.22, v5.4.23, v5.4.24, v5.4.25, v5.4.26, v5.4.27, v5.4.28, v5.4.29, v5.4.30, v5.4.31, v5.4.32, v5.4.33, v5.4.34, v5.4.35, v5.4.36, v5.4.37, v5.4.38, v6.0.0, v6.0.1, v6.0.2, v6.0.3, v6.0.4, v6.0.5, v6.0.6, v6.0.7, v6.0.8, v6.0.9, v6.0.10, v6.0.11, v6.0.12, v6.0.13, v6.0.14, v6.0.15, v6.0.16, v6.0.17, v6.0.18, v6.0.19, v6.0.20, v6.1.0, v6.1.1, v6.1.2, v6.1.3, v6.1.4, v6.1.5, v6.1.6, v6.1.7, v6.1.8, v6.1.9, v6.1.10, v6.1.11, v6.1.12, v6.2.0, v6.2.1, v6.2.2, v6.2.3, v6.2.4, v6.2.5, v6.2.6, v6.2.7, v6.2.8, v6.2.9, v6.2.10, v6.2.11, v6.2.12, v6.2.13, v6.2.14, v6.3.0, v6.3.1, v6.3.2, v6.3.3, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.9, v6.3.10, v6.3.11, v6.3.12, v6.4.0, v6.4.1, v6.4.2, v6.4.3, v6.4.4, v6.4.5, v6.4.6, v7.0.0, v7.0.1, v7.0.2, v7.0.3, v7.0.4, v7.0.5, v7.0.6].
- symfony/twig-bridge[v7.0.0, v7.0.2, v7.0.3, v7.0.4, v7.0.6] conflict with symfony/http-kernel <6.4.
- You can only install one version of a package, so only one of these can be installed: symfony/http-foundation[v4.3.0, v4.3.1, v4.3.2, v4.3.3, v4.3.4, v4.3.5, v4.3.6, v4.3.7, v4.3.8, v4.3.9, v4.3.10, v4.3.11, v4.4.0, v4.4.1, v4.4.2, v4.4.3, v4.4.4, v4.4.5, v4.4.6, v4.4.7, v4.4.8, v4.4.9, v4.4.10, v4.4.11, v4.4.12, v4.4.13, v4.4.14, v4.4.15, v4.4.16, v4.4.17, v4.4.18, v4.4.19, v4.4.20, v4.4.22, v4.4.23, v4.4.25, v4.4.26, v4.4.30, v4.4.33, v4.4.34, v4.4.36, v4.4.37, v4.4.38, v4.4.39, v4.4.41, v4.4.42, v4.4.43, v4.4.44, v4.4.45, v4.4.46, v4.4.47, v4.4.48, v4.4.49, v5.0.0, v5.0.1, v5.0.2, v5.0.3, v5.0.4, v5.0.5, v5.0.6, v5.0.7, v5.0.8, v5.0.9, v5.0.10, v5.0.11, v5.1.0, v5.1.1, v5.1.2, v5.1.3, v5.1.4, v5.1.5, v5.1.6, v5.1.7, v5.1.8, v5.1.9, v5.1.10, v5.1.11, v5.2.0, v5.2.1, v5.2.2, v5.2.3, v5.2.4, v5.2.7, v5.2.8, v5.2.10, v5.2.11, v5.2.12, v5.2.14, v5.3.0, v5.3.1, v5.3.2, v5.3.3, v5.3.4, v5.3.6, v5.3.7, v5.3.10, v5.3.11, v5.3.13, v5.3.14, v5.4.0, v5.4.1, v5.4.2, v5.4.3, v5.4.5, v5.4.6, v5.4.8, v5.4.9, v5.4.10, v5.4.11, v5.4.12, v5.4.13, v5.4.14, v5.4.15, v5.4.16, v5.4.17, v5.4.19, v5.4.20, v5.4.21, v5.4.22, v5.4.23, v5.4.24, v5.4.25, v5.4.26, v5.4.28, v5.4.30, v5.4.31, v5.4.32, v5.4.34, v5.4.35, v5.4.38, v6.0.0, v6.0.1, v6.0.2, v6.0.3, v6.0.5, v6.0.6, v6.0.7, v6.0.8, v6.0.9, v6.0.10, v6.0.11, v6.0.12, v6.0.13, v6.0.14, v6.0.15, v6.0.16, v6.0.17, v6.0.19, v6.0.20, v6.1.0, v6.1.1, v6.1.2, v6.1.3, v6.1.4, v6.1.5, v6.1.6, v6.1.7, v6.1.8, v6.1.9, v6.1.11, v6.1.12, v6.2.0, v6.2.1, v6.2.2, v6.2.5, v6.2.6, v6.2.7, v6.2.8, v6.2.10, v6.2.11, v6.2.12, v6.2.13, v6.3.0, v6.3.1, v6.3.2, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.9, v6.3.11, v6.3.12, v6.4.0, v6.4.2, v6.4.3, v6.4.4, v7.0.0, v7.0.3, v7.0.4, v7.0.6].
- shopware/core v6.6.0.0 requires symfony/http-kernel ~7.0.0 -> satisfiable by symfony/http-kernel[v7.0.0, v7.0.1, v7.0.2, v7.0.3, v7.0.4, v7.0.5, v7.0.6].
- shopware/core v6.6.0.0 requires symfony/twig-bridge ~7.0.0 -> satisfiable by symfony/twig-bridge[v7.0.0, v7.0.2, v7.0.3, v7.0.4, v7.0.6].
- shopware/administration v6.6.0.0 requires symfony/http-foundation ~7.0.0 -> satisfiable by symfony/http-foundation[v7.0.0, v7.0.3, v7.0.4, v7.0.6].
- Root composer.json requires shopware/core 6.6.0.0 -> satisfiable by shopware/core[v6.6.0.0].
- Root composer.json requires symfony/security-bundle ^6.3 -> satisfiable by symfony/security-bundle[v6.3.0, v6.3.1, v6.3.2, v6.3.3, v6.3.4, v6.3.5, v6.3.6, v6.3.7, v6.3.8, v6.3.11, v6.3.12, v6.4.0, v6.4.2, v6.4.3, v6.4.4, v6.4.5, v6.4.6].
Use the option --with-all-dependencies (-W) to allow upgrades, downgrades and removals for packages currently locked to specific versions.
Ich werde daraus nicht wirklich schlau - was ist hier das Problem? Kann mir jemand helfen?
Die PHP Version des Servers ist 8.3.
Wenn ich direkt hoch will auf 6.6.1.1, erhalte ich die gleichen Fehler, nur eben mit anderen Versionsnummern.
LG
Philip
