Use shopware PWA with shopware docker container
Hi everybody,
I’m new in the forum and I’m new in shopware. I find shopware has a great documentation and greats dev solutions, and this is the reason I choosed it to start experiments with PWA and e-commerce.
I have used a dockware/play image to launch an istance of shopware locally (it works and I also installed the pwa plugin) and I would connect it with shopware PWA frontend.  Unfortuntely I have some troubles with the shopware-config.js (below my version):
module.exports = {
  shopwareEndpoint: "angry_gates:80",
  shopwareAccessToken: "xxxxxxxxxxxxxxxxxxx",
I’ve tried to use the docker container name „angry_gates (with :80 and without)“ for the shopwareEndpoint value, but it dosn’t work…I tried the same using „localhost“ , with the same result.
Can someone help me, please?
Thank you
The post is a bit old but perhaps still relevant for others. I’ve played with this myself. I took the dockware/dev image instead, because it includes composer - so I could install the SwagShopwarePwa using composer. Anyway, this worked nicely.
Once you’re able to connect to the Dockware environment using http://localhost, then actually that’s the exact address you need to fill in with shopwareEndpoint. So in my case, it would read:
module.exports = {
  shopwareEndpoint: "http://localhost",
Could it be that you simply tried to enter a hostname, instead of a URL?
