Use menus in shopping worlds
Hi, How can I create the category menu and information menu in the Shopping worlds? So I wan’t something like this: http://www.shopwaredemo.de/deutsch/freizeitwelten/ If I create a shopping world the menu is not visable on the left. I can not find any information on how to get this done. I’m using Shopware 4.2. Thanks in advance, Jason
Hi, that’s a Standard function from the emotion Template. The left menu is visible in shopping worlds (width 808). Landingpages are without the left column and a width 1008. Maybe you have an individual template? Sebastian
[quote=„Sebastian Klöpper“]Hi, that’s a Standard function from the emotion Template. The left menu is visible in shopping worlds (width 808). Landingpages are without the left column and a width 1008. Maybe you have an individual template? Sebastian[/quote] Well, it is a changed copy of the emotion-template. When I set the shopping world width to 808px the menu doesn’t show. Where can I find the associated tpl.-files for the shopping worlds? (I did find menu_left.tpl)> Thanks, Jason
Hallo, I don’t know the changes you did. The regular widgets for emotions you can find here: https://github.com/ShopwareAG/shopware- … ts/emotion Do you have categories and subcategories on the left like this: http://www.shopwaredemo.de/beispiele/?p=1 (regular listing) Sebastian
[quote=„Sebastian Klöpper“]Hallo, I don’t know the changes you did. The regular widgets for emotions you can find here: https://github.com/ShopwareAG/shopware- … ts/emotion Do you have categories and subcategories on the left like this: http://www.shopwaredemo.de/beispiele/?p=1 (regular listing) Sebastian[/quote] Well, it’s a template-adjustment by someone else so I have to do some digging sometimes… However I found the reason and adjusted the index.tpl so now it’s working like it should on the most pages. BUT, what if I want it to show on the homepage? Thanks again.
