Uploading plugin throws error
I’m trying to upload my plugin but every time im getting the error: No extension found in ZIP file.
No plugin was found in the zip archive: /tmp/archive.zipS6WqqQ
I zipped by a NodeJS script, the default MacOS compress and the terminal command zip… Anyone knows what to do?
NodeJS script… Does not sound like a proper Shopware plugin.
bin/console plugin:create abc
As I mentioned I tried also zipping it with NodeJS, doesn’t mean the plugin itself is made with it
I see, got it wrong.
You cannot use the MacOS zip since it is a Apple interpretation of zip, that does not support all headers. Use Keka or other free programs from the Mac AppStore, then it should work.
Hi, I might be late but I had the same problem.
What worked for me was using terminal with the following command:
zip -r Plugin.zip PluginDirectory -x '**/.DS_Store' -x '__MACOSX'
Hope it is still helpful
