wir entwickeln gerade am ImageZoom und der SliderGallery für die Produktdetailseite - hier ist uns aufgefallen, dass die Version der Datei /vendor/shopware/storefront/Resources/app/storefront/src/plugin/zoom-modal/zoom-modal.plugin.js von der Version auf Github abweicht - wie kann das sein, wenn wir auf der aktuellen Shopware Version sind?
Unsere Datei:
import Plugin from 'src/plugin-system/plugin.class';
import PluginManager from 'src/plugin-system/plugin.manager';
import DeviceDetection from 'src/helper/device-detection.helper';
import Iterator from 'src/helper/iterator.helper';
* Zoom Modal Plugin
export default class ZoomModalPlugin extends Plugin {
static options = {
* selector for the zoom modal
modalSelector: '.js-zoom-modal',
* selector to trigger the image zoom modal
triggerSelector: 'img',
* product id to load the images via ajax
productIdDataAttribute: 'data-product-id',
* selector for the gallery slider inside the modal
modalGallerySliderSelector: '[data-modal-gallery-slider]',
* selector for the initial gallery slider
parentGallerySliderSelector: '[data-gallery-slider]',
* selector for gallery images which use the image zoom
imageZoomInitSelector: '[data-image-zoom]',
* selector for the container of the gallery and the zoom modal
galleryZoomModalContainerSelector: '.js-gallery-zoom-modal-container'
init() {
this._triggers = this.el.querySelectorAll(this.options.triggerSelector);
this._clickInterrupted = false;
this._registerEvents();
* @private
_registerEvents() {
const eventType = (DeviceDetection.isTouchDevice()) ? 'touchend' : 'click';
Iterator.iterate(this._triggers, element => {
element.removeEventListener(eventType, this._onClick.bind(this));
element.addEventListener(eventType, this._onClick.bind(this));
element.removeEventListener('touchmove', this._onTouchMove.bind(this));
element.addEventListener('touchmove', this._onTouchMove.bind(this));
* @param event
* @private
_onClick(event) {
if (this._clickInterrupted === true) {
return;
ZoomModalPlugin._stopEvent(event);
this._openModal();
this.$emitter.publish('onClick');
* @private
_onTouchMove() {
this._clickInterrupted = true;
* @private
_openModal() {
const galleryZoomModalContainer = this.el.closest(this.options.galleryZoomModalContainerSelector);
const modal = galleryZoomModalContainer.querySelector(this.options.modalSelector);
if (modal) {
// execute all needed scripts for the slider
const $modal = $(modal);
$modal.off('shown.bs.modal');
$modal.on('shown.bs.modal', () => {
this._initSlider(modal);
this.$emitter.publish('modalShow', { modal });
$modal.modal('show');
this.$emitter.publish('onClick', { modal });
* init the gallery slider or update the position of the slider
* @private
_initSlider(modal) {
const slider = modal.querySelector(this.options.modalGallerySliderSelector);
if (!slider) {
return;
const parentSliderIndex = this._getParentSliderIndex();
if (this.gallerySliderPlugin && this.gallerySliderPlugin._slider) {
this.gallerySliderPlugin._slider.goTo(parentSliderIndex - 1);
return;
PluginManager.initializePlugin('GallerySlider', slider, {
slider: {
startIndex: parentSliderIndex,
touch: false
thumbnailSlider: {
autoWidth: true,
responsive: {
md: {
enabled: true
lg: {
enabled: true
xl: {
enabled: true,
axis: 'horizontal'
this.gallerySliderPlugin = PluginManager.getPluginInstanceFromElement(slider, 'GallerySlider');
this._registerImageZoom();
this.$emitter.publish('initSlider');
* register indexChanged callback to update the image zoom button state
* @private
_registerImageZoom() {
this._updateImageZoom();
this.gallerySliderPlugin._slider.events.on('indexChanged', this._updateImageZoom.bind(this));
* updates the image zoom instance after a slider event
* @private
_updateImageZoom() {
const activeSlideElement = this.gallerySliderPlugin.getActiveSlideElement();
if (!activeSlideElement) return;
const activeImageZoomElement = activeSlideElement.querySelector(this.options.imageZoomInitSelector);
if (!activeImageZoomElement) return;
const imageZoomPlugin = PluginManager.getPluginInstanceFromElement(activeImageZoomElement, 'ImageZoom');
if (!imageZoomPlugin) return;
imageZoomPlugin.update();
* returns the current index of the parent slider
* @return {number}
* @private
_getParentSliderIndex() {
let sliderIndex = 1;
this._parentSliderElement = this.el.closest(this.options.parentGallerySliderSelector);
if (this._parentSliderElement) {
this._parentSliderPlugin = PluginManager.getPluginInstanceFromElement(this._parentSliderElement, 'GallerySlider');
if (this._parentSliderPlugin) {
sliderIndex = this._parentSliderPlugin.getCurrentSliderIndex();
return sliderIndex + 1;
* @param event
* @private
static _stopEvent(event) {
if (event) {
event.stopPropagation();
event.preventDefault();
Die Datei auf Github:
Funktioniert hier generell etwas nicht beim Update-Prozess?
