Update Shopware 6 Fehler
wir haben gerade versucht unser Shopware 5 auf die Version 6.4.17.1 mittels Upgrade-Wizzard, durchzuführen.
Leider kommt bei der DB-Upgrader folgender Fehler:
Error
Received an error message.
URL: applyMigrations?offset=0&total=0
Message: Internal Server Error
Response
Slim Application Error
Type: UnexpectedValueException
Message: DirectoryIterator::__construct(/var/www/vhosts/domain.com/httpdocs/update-assets/migrations/): Failed to open directory: No such file or directory
File: /var/www/vhosts/domain.com/httpdocs/engine/Shopware/Components/Migrations/Manager.php
Line: 179
Trace
#0 /var/www/vhosts/domain.com/httpdocs/engine/Shopware/Components/Migrations/Manager.php(179): DirectoryIterator->__construct(‚/var/www/vhosts…‘)
#1 /var/www/vhosts/domain.com/httpdocs/recovery/update/src/Steps/MigrationStep.php(59): Shopware\Components\Migrations\Manager->getMigrationsForVersion(1720)
#2 /var/www/vhosts/domain.com/httpdocs/recovery/update/src/Controller/BatchController.php(101): Shopware\Recovery\Update\Steps\MigrationStep->run(‚0‘, ‚0‘)
#3 /var/www/vhosts/domain.com/httpdocs/recovery/update/src/app.php(151): Shopware\Recovery\Update\Controller\BatchController->applyMigrations()
#4 [internal function]: {closure}()
#5 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#6 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#7 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#8 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#10 /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#11 /var/www/vhosts/domain.com/httpdocs/recovery/update/index.php(57): Slim\Slim->run()
#12 {main}
Kann jemand helfen?
Kann es sein, dass ich kein direktes Update von 5.X auf die aktuelleste machen kann?
ein direktes Upgrade von Shopware 5 auf 6 ist nicht möglich. Weitere Details findest Du z.B. hier: https://www.codeblick.de/blog/umzug-von-shopware5-zu-shopware6/
