ich habe schon viele Updates gemacht und nie gab es ein Problem. Nun endet mein Update direkt in diesem Fehler und ich habe keine Ahnung, was ich tun kann. Bitte helft mir, mein Shop ist jetzt offline ![]()
Error
Received an error message.
URL: unpack?offset=0&total=0
Message: Internal Server ErrorPlease try to fix this error and restart the update.
Response
Slim Application Error
Type: Gaufrette\Exception\UnexpectedFile
Message: The file „vendor/php-http/message/src/filters.php“ was not supposed to exist.
File: /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/knplabs/gaufrette/src/Gaufrette/Filesystem.php
Line: 72
Trace
#0 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/update/src/Steps/UnpackStep.php(130): Gaufrette\Filesystem->rename(‚files/update/fi…‘, ‚vendor/php-http…‘)#1 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/update/src/Controller/BatchController.php(142): Shopware\Recovery\Update\Steps\UnpackStep->run(‚0‘, ‚0‘)#2 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/update/src/app.php(154): Shopware\Recovery\Update\Controller\BatchController->unpack()#3 [internal function]: {closure}()#4 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#5 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#6 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#7 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#8 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#9 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#10 /var/www/vhosts/abozkurt.www6.hostkraft.de/httpdocs/hnpw_sw/recovery/update/index.php(57): Slim\Slim->run()
#11 {main}
