Updateproblem auf Xampp
ich wollte von aktuell 5,3 auf 5,31 aktualisieren. Dabei erhalte ich die Fehlermeldung
“Gaufrette\Exception\FileNotFound”
kann da wer helfen?
Danke, Jozi
hier die genaue Fehllermeldung:
Error
Received an error message.
URL: unpack?offset=0&total=0
Message: Internal Server Error
Response
Slim Application Error
Type: Gaufrette\Exception\FileNotFound
Message: The file „files/update/files/G:\xampp\htdocs\shopware5/files/update/files.php_cs.dist“ was not found.
File: G:\xampp\htdocs\shopware5\recovery\common\vendor\knplabs\gaufrette\src\Gaufrette\Filesystem.php
Line: 332
Trace
#0 G:\xampp\htdocs\shopware5\recovery\common\vendor\knplabs\gaufrette\src\Gaufrette\Filesystem.php(69): Gaufrette\Filesystem->assertHasFile(‚files/update/fi…‘)
#1 G:\xampp\htdocs\shopware5\recovery\update\src\Steps\UnpackStep.php(130): Gaufrette\Filesystem->rename(‚files/update/fi…‘, ‚G:\xampp\htdocs…‘)
#2 G:\xampp\htdocs\shopware5\recovery\update\src\Controller\BatchController.php(142): Shopware\Recovery\Update\Steps\UnpackStep->run(‚0‘, 11702)
#3 G:\xampp\htdocs\shopware5\recovery\update\src\app.php(154): Shopware\Recovery\Update\Controller\BatchController->unpack()
#4 [internal function]: {closure}()
#5 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Route.php(462): call_user_func_array(Object(Closure), Array)
#6 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Slim.php(1326): Slim\Route->dispatch()
#7 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Middleware\Flash.php(85): Slim\Slim->call()
#8 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Middleware\MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Middleware\PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#10 G:\xampp\htdocs\shopware5\recovery\common\vendor\slim\slim\Slim\Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#11 G:\xampp\htdocs\shopware5\recovery\update\index.php(69): Slim\Slim->run()
#12 {main}
