Hallo, wir nutzen Shopware 4.3.0 auf Nginx. Bei der Auswahl einer Kategorie über das Menü erscheint ständig der folgende Fehler: ____________________ Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘t3.supplierID’ in ‘on clause’ in Zend/Db/Statement/Pdo.php on line 234 Stack trace: #0 Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array) #1 Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array) #2 Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(’? SE…’, Array) #3 Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend_Db_Adapter_Pdo_Abstract->query(’? SE…’, Array) #4 Zend/Db/Adapter/Abstract.php(737): Enlight_Components_Db_Adapter_Pdo_Mysql->query(’? SE…’, Array) #5 Shopware/Components/Search/Adapter/Default.php(1366): Zend_Db_Adapter_Abstract->fetchAll(’? SE…’) #6 Shopware/Components/Search/Adapter/Default.php(1262): Shopware_Components_Search_Adapter_Default->cleanupIndex() #7 Shopware/Components/Search/Adapter/Default.php(374): Shopware_Components_Search_Adapter_Default->buildSearchIndex() #8 Shopware/Components/Search/Adapter/Default.php(273): Shopware_Components_Search_Adapter_Default->validateCache(Object(Shopware_Components_Config)) #9 Shopware/Plugins/Community/Frontend/VerignPriceFilter/Bootstrap.php(634): Shopware_Components_Search_Adapter_Default->__construct() #10 Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Frontend_VerignPriceFilter_Bootstrap->onFilterSQL(Object(Enlight_Event_EventArgs)) #11 Enlight/Event/EventManager.php(301): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Event_EventArgs)) #12 engine/core/class/sArticles.php(1150): Enlight_Event_EventManager->filter(‘Shopware_Module…’, ‘? SE…’, Array) #13 Shopware/Controllers/Frontend/Listing.php(162): sArticles->sGetArticlesByCategory(138) #14 Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Listing->indexAction() #15 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘indexAction’) #16 Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #17 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #18 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #19 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #20 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #21 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #22 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #23 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #24 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #25 shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #26 {main} _________ EDIT: Scheinbar liegt es am ‘Verign Price Filter’. Dabei ist es egal, welche Version wir installieren: Sobald das Plugin deaktiviert ist, tritt die Fehlermeldung nicht mehr auf. { Den http-Cache haben wir bereits testweise deaktiviert / aktiviert, das behebt den Fehler auch nicht. } Danke im Voraus! Grüsse
Hallo, hat Niemand eine Idee, woran es liegen könnte?
Wirklich Niemand?
