Unable to load template snippet 'widgets/error/generic_error.tpl'
We are receiving multiple email errors on our customers site following the latest update:
 exception 'SmartyException' with message 'Unable to load template snippet 'widgets/error/generic\_error.tpl'' in /var/www/html/engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php:127
How can I resolve this issue?
Message:
 Stack trace:
 #0 /var/www/html/engine/Library/Enlight/View/Default.php(300): Smarty\_Internal\_TemplateBase-\>fetch()
 #1 /var/www/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #2 /var/www/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #3 /var/www/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #4 (internal function): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #5 /var/www/html/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #6 /var/www/html/engine/Library/Enlight/Event/EventManager.php(219): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #7 /var/www/html/engine/Library/Enlight/Controller/Action.php(235): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #8 /var/www/html/engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight\_Controller\_Action-\>dispatch('genericErrorAct...')
 #9 /var/www/html/engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #10 /var/www/html/engine/Shopware/Kernel.php(202): Enlight\_Controller\_Front-\>dispatch()
 #11 /var/www/html/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #12 /var/www/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #13 /var/www/html/engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #14 /var/www/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #15 /var/www/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true)
 #16 /var/www/html/engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true)
 #17 /var/www/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true)
 #18 /var/www/html/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #19 /var/www/html/shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #20 {main}
Time:
 2019-04-26T09:11:54.466479+0200
Channel:
 core
request:
     "uri": "/durable/widgets/index/refreshStatistic?requestPage=%2Fdurable%2Finformation-and-presentation%2Fsecurity-pass-holders%2Fsecurity-pass-holder-without-attachment%2F1715%2Fdual-security-pass-holder-holder-only-transparent-pk10&requestController=detail&articleId=1715",
     "method": "GET",
     "query": {
         "requestPage": "/durable/information-and-presentation/security-pass-holders/security-pass-holder-without-attachment/1715/dual-security-pass-holder-holder-only-transparent-pk10",
         "requestController": "detail",
         "articleId": "1715",
         "module": "widgets",
         "controller": "durable",
         "action": "index",
         "refreshStatistic": ""
     "post": []
session:
 No session data available
shopId:
 1
Hi, any progress at that?
getting exactly the same error at a client’s Shop after latest Update
Seeing exactly the same error
I also get this error for marketing–shopping-worlds (Einkaufswelten). You can get the real error if you turn on exceptions in config:
'phpsettings' => [
	'display_errors' => 1,
'front' => [
	'showException' => true,
	'throwExceptions' => true,
	'noErrorHandler' => false,
'template' => [
	'forceCompile' => true,
'model' => [
	'cacheProvider' => 'array'
'httpCache' => [
	'enabled' => false, // true or false
	'debug' => true,
In my case it was: modifier ‚mb_substr‘ not allowed by security setting
how did you solve this?
Replace the function by another one mb_substr is deprecated in smarty 3
I’m getting the same error 8.000 times when the cron clears the cache using the sw-cli. How to solve this?
PHP Fatal error: Uncaught SmartyException: Unable to load template snippet ‘widgets/error/generic_error.tpl’ in /var/www/vhosts/shop/httpdocs/production/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127
How did you solve that error? I’m currently having the same issue after an update from SW 5.6.9 to 5.7.2.
