Detail Seite: Unable to load template snippet
habe jetzt von 5.4.6 auf 5.5.10 und nun endgültig auf 5.6.4 geupdatet. Beim ersten Sprung gab es keine Probleme. Beim zweiten musste ich einiges am Template korrigieren. Nun läuft alles. Aber trotzdem steht im Log folgendes:
SmartyException: Unable to load template snippet 'frontend/detail/xxx.tpl|frontend/plugins/seo/index.tpl' in /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace:
#0 /engine/Library/Enlight/View/Default.php(295): Smarty_Internal_TemplateBase->fetch()
#1 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default))
#2 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#3 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#4 /engine/Library/Enlight/Event/Handler/Default.php(87): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 /engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#6 /engine/Library/Enlight/Controller/Action.php(233): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#7 /engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch('indexAction')
#8 /engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 /engine/Shopware/Kernel.php(186): Enlight_Controller_Front->dispatch()
#10 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(447): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(420): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /engine/Shopware/Components/HttpCache/AppCache.php(183): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /engine/Shopware/Components/HttpCache/AppCache.php(110): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#18 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#19
Kann mir jemand auf die Sprünge helfen, woran das liegen kann? Blicke im Moment nicht mehr durch.
Vielen Dank für die Hilfe.
HEPI
Da ich mir einen Wolf suche und ich glaube, es wäre einfacher, wenn ein Profi den Code sieht:
{extends file='parent:frontend/detail/index.tpl'}
{block name='frontend_detail_index_data'}
    {if $sArticle.sBlockPrices}
        {$lowestPrice=false}
        {$highestPrice=false}
        {foreach $sArticle.sBlockPrices as $blockPrice}
            {if $lowestPrice === false || $blockPrice.price < $lowestPrice}
                {$lowestPrice=$blockPrice.price}
            {/if}
            {if $highestPrice === false || $blockPrice.price > $highestPrice}
                {$highestPrice=$blockPrice.price}
            {/if}
        {/foreach}
    {else}
    {/if}
{/block}
{* Configurator drop down menu's *}
{block name="frontend_detail_index_configurator"}
        {if $hpFarbIcon && $smarty.get.number && $smarty.get.number != ''}
            {include file="frontend/detail/config_variant.tpl"}
        {else}
            {include file="frontend/detail/config_farbicon.tpl"}
        {/if}
{/block}
{* Include buy button and quantity box *}
{block name="frontend_detail_index_buybox"}
        {include file="frontend/detail/buy.tpl"}
    {/if}
{/block}
{* Product SKU *}
{block name='frontend_detail_data_ordernumber'}
        {* Product SKU - Label *}
            Artikel-Nr.:
        {if $sArticle.sProperties[4].value}
        {/if}
            {$sArticle.mainVariantNumber}
{/block}
{* Main content *}
{block name='frontend_index_content'}
        {include file="frontend/detail/content.tpl"}
    {else}
        {include file="frontend/detail/content_farbicon.tpl"}
    {/if}
{/block}
Danke.
Unable to load template snippet ‚frontend/detail/xxx.tpl|frontend/plugins/seo/index.tpl‘
Die Datei wird ja sicherlich nicht xxx.tpl heißen oder? Musst schon genau schreiben welche Datei nicht geladen wurde :-)
Eigenes Template (index_farbicon.tpl) . Wird auch geladen, aber die Fehlermeldung steht hin und wieder im Log. Ich weiß nicht, woher die kommt, kann sie nicht reproduzieren und habe auch atuell keine Idee, an was es liegen könnte. Daher habe ich ja nicht nur die Fehlermeldung, sondern auch die Templatedatei ansich reingestellt.
Habe schon gedacht, es könnte hieran liegen: $smarty.get.number
Aber laut Anleitung ist das korrekt. Will nicht unbedingt $_GET[‘number’] schreiben, was wahrscheinlich im Template auch nicht funktionieren wird.
Es lief auch alles fehlerlos, bis zum Update auf 5.6.4 .
