The admin side snippets are not showing in Settings->Snippets
Hi
Is there any way to show the admin side snippets also in snippets so that the admin can change the admin side snippet also.
Admin snippets are stored in json files. These are included in several admin plugins.
Search on GitHub for the sentence. Then change the snippet and I guess you have then to build the administration again (not sure if last step is necessary).
Thank you @Max_Shop
But only the developer can change the text in that way.
How a normal administrator can do it?
Just go the the console and execute the build-administration.sh then your changes will be applied.
There is no other way.
