Hallo, bin wie hier beschrieben vorgegangen: https://devdocs.shopware.com/designers- … g-started/ und habe in meinem Theme die im Beispiel erwähnte Datei geändert: [code] {extends file=“parent:frontend/index/shop-navigation.tpl”}
{* Menu (Off canvas left) trigger *}
{block name='frontend_index_offcanvas_left_trigger'}
<li class="navigation--entry entry--menu-left" role="menuitem">
<a class="entry--link entry--trigger btn is--icon-left" href="#offcanvas--left" data-offcanvas="true" data-offcanvasselector=".sidebar-main">
<i class="icon--menu"></i> {s namespace='frontend/index/menu_left' name="IndexLinkMenu"}{/s}
</a>
</li>
{/block}
{* Search form *}
{block name='frontend_index_search'}
<li class="navigation--entry entry--search" role="menuitem" data-search="true" aria-haspopup="true" data-activeonstart="true">
<a class="btn entry--link entry--trigger" href="#show-hide--search" title="{" namespace="frontend/index/search" name="IndexTitleSearchToggle">
<i class="icon--search"></i>
{block name='frontend_index_search_display'}
Suchfeld
<span class="search--display">{s namespace='frontend/index/search' name="IndexSearchFieldSubmit"}{/s}</span>
{/block}
</a>
{* Include of the search form *}
{block name='frontend_index_search_include'}
{include file="frontend/index/search.tpl"}
{/block}
</li>
{/block}
{* Cart entry *}
{block name='frontend_index_checkout_actions'}
{* Include of the cart *}
{block name='frontend_index_checkout_actions_include'}
{action module=widgets controller=checkout action=info}
{/block}
{/block}
</ul>
[/code] Die Änderunegn werden nicht angezigt. Was habe ich übersehen? Danke P.
