kann SwagMediaS3 nicht istallieren.
Bekomme folgende Fehlermeldung:
Do not run Composer as root/super user! See https://getcomposer.org/root for details
Loading composer repositories with package information
Installing dependencies from lock file
Warning: The lock file is not up to date with the latest changes in composer.json. You may be getting outdated dependencies. Run update to update them.
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Installation request for aws/aws-sdk-php 3.32.6 -> satisfiable by aws/aws-sdk-php[3.32.6].
- aws/aws-sdk-php 3.32.6 requires guzzlehttp/guzzle ^5.3.1|^6.2.1 -> no matching package found.
Problem 2
- Installation request for league/flysystem-aws-s3-v3 1.0.13 -> satisfiable by league/flysystem-aws-s3-v3[1.0.13].
- league/flysystem-aws-s3-v3 1.0.13 requires league/flysystem ~1.0 -> no matching package found.
Potential causes:
- A typo in the package name
- The package is not available in a stable-enough version according to your minimum-stability setting
see https: for more details.
- It’s a private package and you forgot to add a custom repository to find it</https:>
Read https: for further common problems.
adding: SwagMediaS3/ (stored 0%)
adding: SwagMediaS3/.gitignore (stored 0%)
adding: SwagMediaS3/plugin.xml (deflated 41%)
adding: SwagMediaS3/build.sh (deflated 48%)
adding: SwagMediaS3/SwagMediaS3.php (deflated 60%)
adding: SwagMediaS3/composer.json (deflated 47%)
adding: SwagMediaS3/README.rst (deflated 50%)
adding: SwagMediaS3/composer.lock (deflated 82%)
adding: SwagMediaS3/LICENSE (deflated 42%)</https:>
danach bricht er ab.
