Hi nach dem Update auf 5.7.8 geht nix mehr Seite weiss - Der Aufruf über recovery/update/ funktioniert noch. Beim Migrieren der DB kommt folgender Fehler:
Error
Received an error message.
URL: applyMigrations?offset=0&total=0
Message: Internal Server Error
Response
Slim Application Error
Type: ErrorException
Code: 2
Message: require(/var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/config.php): failed to open stream: No such device
File: /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/Utils.php
Line: 201
Trace
#0 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/Utils.php(201): Slim\Slim::handleErrors()
#1 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/Utils.php(201): require()
#2 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/DependencyInjection/Container.php(61): Shopware\Recovery\Update\Utils::getConnection()
#3 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(122): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}()
#4 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/src/DependencyInjection/Container.php(73): Pimple\Container->offsetGet()
#5 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/DependencyInjection/Container.php(82): Shopware\Recovery\Common\DependencyInjection\Container->get()
#6 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(122): Shopware\Recovery\Update\DependencyInjection\Container->Shopware\Recovery\Update\DependencyInjection{closure}()
#7 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/src/DependencyInjection/Container.php(73): Pimple\Container->offsetGet()
#8 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/Controller/BatchController.php(96): Shopware\Recovery\Common\DependencyInjection\Container->get()
#9 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/src/app.php(151): Shopware\Recovery\Update\Controller\BatchController->applyMigrations()
#10 [internal function]: {closure}()
#11 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array()
#12 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#13 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#14 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#15 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#16 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#17 /var/www/vhosts/idealnet.de/stage.idealnet.de/shop/files/downloads/recovery/update/index.php(57): Slim\Slim->run()
#18 {main}
Hat jemand eine Idee?? Danke und VG
