Hallo Zusammen,
wir sind vor kurzen von IONOS zu Profihost gewechselt. Der Umstieg verlief reibungslos, doch nun haben wir das Problem das wir nicht updaten können, wir bekommen folgende Fehlermeldung
"9": /engine/php.ini",
"10": /engine/Library/php.ini",
"11": /engine/Library/Doctrine/php.ini",
"12": /engine/Library/Doctrine/Common/php.ini",
"13": /engine/Library/Doctrine/Common/Proxy/php.ini",
"14": /engine/Library/Doctrine/ORM/php.ini",
"15": /engine/Library/Doctrine/ORM/Persisters/php.ini",
"16": /engine/Library/Doctrine/ORM/Persisters/Entity/php.ini",
"17": /engine/Library/Enlight/php.ini",
"18": /engine/Library/Enlight/Collection/php.ini",
"19": /engine/Library/Enlight/Components/php.ini",
"20": /engine/Library/Enlight/Components/Auth/php.ini",
"21": /engine/Library/Enlight/Components/Auth/Adapter/php.ini",
"22": /engine/Library/Enlight/Components/Cron/php.ini",
"23": /engine/Library/Enlight/Components/Cron/Adapter/php.ini",
"24": /engine/Library/Enlight/Components/Db/php.ini",
"25": /engine/Library/Enlight/Components/Db/Adapter/php.ini",
"26": /engine/Library/Enlight/Components/Db/Adapter/Pdo/php.ini",
"27": /engine/Library/Enlight/Components/Session/php.ini",
"28": /engine/Library/Enlight/Components/Session/SaveHandler/php.ini",
"29": /engine/Library/Enlight/Components/Snippet/php.ini",
"30": /engine/Library/Enlight/Components/Table/php.ini",
"31": /engine/Library/Enlight/Components/Test/php.ini",
"32": /engine/Library/Enlight/Components/Test/Controller/php.ini",
"33": /engine/Library/Enlight/Components/Test/Plugin/php.ini",
"34": /engine/Library/Enlight/Config/php.ini",
"35": /engine/Library/Enlight/Config/Adapter/php.ini",
"36": /engine/Library/Enlight/Config/Format/php.ini",
"37": /engine/Library/Enlight/Config/Writer/php.ini",
"38": /engine/Library/Enlight/Controller/php.ini",
"39": /engine/Library/Enlight/Controller/Dispatcher/php.ini",
"40": /engine/Library/Enlight/Controller/Plugins/php.ini",
"41": /engine/Library/Enlight/Controller/Plugins/Json/php.ini",
"42": /engine/Library/Enlight/Controller/Plugins/JsonRequest/php.ini",
"43": /engine/Library/Enlight/Controller/Plugins/ScriptRenderer/php.ini",
"44": /engine/Library/Enlight/Controller/Plugins/ViewRenderer/php.ini",
"45": /engine/Library/Enlight/Controller/Request/php.ini",
"46": /engine/Library/Enlight/Controller/Response/php.ini",
"47": /engine/Library/Enlight/Event/php.ini",
"48": /engine/Library/Enlight/Event/Handler/php.ini",
"49": /engine/Library/Enlight/Event/Subscriber/php.ini",
"50": /engine/Library/Enlight/Hook/php.ini",
"51": /engine/Library/Enlight/Plugin/php.ini",
"52": /engine/Library/Enlight/Plugin/Bootstrap/php.ini",
"53": /engine/Library/Enlight/Plugin/Namespace/php.ini",
"54": /engine/Library/Enlight/Template/php.ini",
"55": /engine/Library/Enlight/Template/Plugins/php.ini",
"56": /engine/Library/Enlight/View/php.ini",
"57": /engine/Library/ExtJs/php.ini",
"58": /engine/Library/ExtJs/components/php.ini",
"59": /engine/Library/ExtJs/locale/php.ini",
"60": /engine/Library/ExtJs/overrides/php.ini",
"61": /engine/Library/ExtJs/resources/php.ini",
"62": /engine/Library/ExtJs/resources/css/php.ini",
"63": /engine/Library/ExtJs/resources/sass/php.ini",
"64": /engine/Library/ExtJs/resources/themes/php.ini",
"65": /engine/Library/ExtJs/resources/themes/images/php.ini",
"66": /engine/Library/ExtJs/resources/themes/images/default/php.ini",
"67": /engine/Library/ExtJs/resources/themes/images/default/boundlist/php.ini",
"68": /engine/Library/ExtJs/resources/themes/images/default/box/php.ini",
"69": /engine/Library/ExtJs/resources/themes/images/default/btn-group/php.ini",
"70": /engine/Library/ExtJs/resources/themes/images/default/btn/php.ini",
"71": /engine/Library/ExtJs/resources/themes/images/default/button/php.ini",
"72": /engine/Library/ExtJs/resources/themes/images/default/datepicker/php.ini",
"73": /engine/Library/ExtJs/resources/themes/images/default/dd/php.ini",
"74": /engine/Library/ExtJs/resources/themes/images/default/editor/php.ini",
"75": /engine/Library/ExtJs/resources/themes/images/default/form-invalid-tip/php.ini",
"76": /engine/Library/ExtJs/resources/themes/images/default/form/php.ini",
"77": /engine/Library/ExtJs/resources/themes/images/default/grid/php.ini",
"78": /engine/Library/ExtJs/resources/themes/images/default/layout/php.ini",
"79": /engine/Library/ExtJs/resources/themes/images/default/menu/php.ini",
"80": /engine/Library/ExtJs/resources/themes/images/default/panel-header/php.ini",
"81": /engine/Library/ExtJs/resources/themes/images/default/panel/php.ini",
"82": /engine/Library/ExtJs/resources/themes/images/default/progress/php.ini",
"83": /engine/Library/ExtJs/resources/themes/images/default/shared/php.ini",
"84": /engine/Library/ExtJs/resources/themes/images/default/sizer/php.ini",
"85": /engine/Library/ExtJs/resources/themes/images/default/slider/php.ini",
"86": /engine/Library/ExtJs/resources/themes/images/default/tab-bar/php.ini",
"87": /engine/Library/ExtJs/resources/themes/images/default/tab/php.ini",
"88": /engine/Library/ExtJs/resources/themes/images/default/tip/php.ini",
"89": /engine/Library/ExtJs/resources/themes/images/default/toolbar/php.ini",
"90": /engine/Library/ExtJs/resources/themes/images/default/tools/php.ini",
"91": /engine/Library/ExtJs/resources/themes/images/default/tree/php.ini",
"92": /engine/Library/ExtJs/resources/themes/images/default/util/php.ini",
"93": /engine/Library/ExtJs/resources/themes/images/default/util/splitter/php.ini",
"94": /engine/Library/ExtJs/resources/themes/images/default/window-header/php.ini",
"95": /engine/Library/ExtJs/resources/themes/images/default/window/php.ini",
"96": /engine/Library/ExtJs/resources/themes/lib/php.ini",
"97": /engine/Library/ExtJs/resources/themes/stylesheets/php.ini",
"98": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/php.ini",
"99": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/php.ini",
"100": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/core/php.ini",
"101": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/layout/php.ini",
"102": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/mixins/php.ini",
"103": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/util/php.ini",
"104": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/variables/php.ini",
"105": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/widgets/php.ini",
"106": /engine/Library/ExtJs/resources/themes/stylesheets/ext4/default/widgets/form/php.ini",
"107": /engine/Library/ExtJs/resources/themes/templates/php.ini",
"108": /engine/Library/ExtJs/resources/themes/templates/resources/php.ini",
"109": /engine/Library/ExtJs/resources/themes/templates/resources/sass/php.ini",
"110": /engine/Library/Mpdf/php.ini",
"111": /engine/Library/Mpdf/ttfonts/php.ini",
"112": /engine/Library/Smarty/php.ini",
"113": /engine/Library/Smarty/plugins/php.ini",
"114": /engine/Library/Smarty/sysplugins/php.ini",
"115": /engine/Library/TinyMce/php.ini",
"116": /engine/Library/TinyMce/langs/php.ini",
"117": /engine/Library/TinyMce/plugins/php.ini",
"118": /engine/Library/TinyMce/plugins/advhr/php.ini",
"119": /engine/Library/TinyMce/plugins/advhr/css/php.ini",
"120": /engine/Library/TinyMce/plugins/advhr/js/php.ini",
"121": /engine/Library/TinyMce/plugins/advhr/langs/php.ini",
"122": /engine/Library/TinyMce/plugins/advimage/php.ini",
"123": /engine/Library/TinyMce/plugins/advimage/css/php.ini",
"124": /engine/Library/TinyMce/plugins/advimage/img/php.ini",
"...": "Over 1000 items (20005 total), aborting normalization"
Diese ganze php.ini Datein existieren aber auch nicht, und dürften damals bei IONOS durch einen symlink erstellt worden sein.
Hat jemand rat wie wir diesen Fehler beheben könnten?
LG
