Error 500 bei Update von 6.5.2.1 auf 6.5.3.1
Hallo zusammen, ich bin zwar nicht ganz neu bei Shopware, mache aber gerade die ersten Schritte mit Shopware 6 auf Profihost. Beim Update von 6.5.2.1 auf 6.5.3.1 kam es dabei zu einem http-error 500 mit folgendem Log aus dem Update. Hat jemand eine Idee wo man da ansetzen kann? Sonst lief der Shop stabil ist gerade erst in einer frühen Phase der Entwicklung.
PHP Warning:  Failed loading Zend extension 'ioncube.so' (tried: /usr/local/php_extensions/php8.2/ioncube.so (/usr/local/php_extensions/php8.2/ioncube.so: cannot open shared object file: No such file or directory), /usr/local/php_extensions/php8.2/ioncube.so.so (/usr/local/php_extensions/php8.2/ioncube.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
Info from https://repo.packagist.org: #StandWithUkraine
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.008 seconds
Analyzed 868 packages to resolve dependencies
Analyzed 5828 rules to resolve dependencies
Lock file operations: 1 install, 8 updates, 0 removals
Installs: league/flysystem-local:3.15.0
Updates: google/cloud-core:v1.52.1, lcobucci/clock:3.1.0, league/flysystem:3.15.1, google/cloud-storage:v1.33.0, shopware/core:v6.5.3.1, shopware/storefront:v6.5.3.1, shopware/administration:v6.5.3.1, shopware/elasticsearch:v6.5.3.1
  - Upgrading google/cloud-core (v1.52.0 => v1.52.1)
  - Upgrading google/cloud-storage (v1.32.0 => v1.33.0)
  - Upgrading lcobucci/clock (3.0.0 => 3.1.0)
  - Upgrading league/flysystem (3.10.4 => 3.15.1)
  - Locking league/flysystem-local (3.15.0)
  - Upgrading shopware/administration (v6.5.2.1 => v6.5.3.1)
  - Upgrading shopware/core (v6.5.2.1 => v6.5.3.1)
  - Upgrading shopware/elasticsearch (v6.5.2.1 => v6.5.3.1)
  - Upgrading shopware/storefront (v6.5.2.1 => v6.5.3.1)
Writing lock file
Installing dependencies from lock file (including require-dev)
> pre-operations-exec: Symfony\Flex\Flex->recordOperations
Package operations: 1 install, 8 updates, 0 removals
  - Downloading google/cloud-core (v1.52.1)
  - Downloading lcobucci/clock (3.1.0)
  - Downloading league/flysystem (3.15.1)
  - Downloading league/flysystem-local (3.15.0)
  - Downloading google/cloud-storage (v1.33.0)
  - Downloading shopware/core (v6.5.3.1)
  - Downloading shopware/storefront (v6.5.3.1)
  - Downloading shopware/administration (v6.5.3.1)
  - Downloading shopware/elasticsearch (v6.5.3.1)
  - Upgrading google/cloud-core (v1.52.0 => v1.52.1): Extracting archive
  - Upgrading lcobucci/clock (3.0.0 => 3.1.0): Extracting archive
  - Upgrading league/flysystem (3.10.4 => 3.15.1): Extracting archive
  - Installing league/flysystem-local (3.15.0): Extracting archive
  - Upgrading google/cloud-storage (v1.32.0 => v1.33.0): Extracting archive
  - Upgrading shopware/core (v6.5.2.1 => v6.5.3.1): Extracting archive
  - Upgrading shopware/storefront (v6.5.2.1 => v6.5.3.1): Extracting archive
  - Upgrading shopware/administration (v6.5.2.1 => v6.5.3.1): Extracting archive
  - Upgrading shopware/elasticsearch (v6.5.2.1 => v6.5.3.1): Extracting archive
> post-package-update: Symfony\Flex\Flex->enableThanksReminder
> post-package-install: Symfony\Flex\Flex->recordFlexInstall
Generating optimized autoload files
> post-autoload-dump: Symfony\Component\Runtime\Internal\ComposerPlugin->updateAutoloadFile
108 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
> post-update-cmd: Symfony\Flex\Flex->update
What about running composer global require symfony/thanks && composer thanks now?
This will spread some 💖  by sending a ★  to the GitHub repositories of your fellow package maintainers.
Run composer recipes at any time to see the status of your Symfony recipes.
Found 1 security vulnerability advisory affecting 1 package.
Run composer audit for a full list of advisories.
Symfony operations: 18 recipes (b1287ced293821aaed0612a813416566)
  - Configuring symfony/flex (>=1.0): From github.com/symfony/recipes:main
    Copying files from recipe
      Created "./.env"
  - Configuring symfony/framework-bundle (>=5.4): From github.com/shopware/recipes:main
    Enabling the package as a Symfony bundle
      Created "./config/services.yaml"
  - Configuring doctrine/annotations (>=1.0): From github.com/shopware/recipes:main
  - Configuring nyholm/psr7 (>=1.0): From github.com/symfony/recipes:main
      Created "./config/packages/nyholm_psr7.yaml"
  - Configuring shopware/administration (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/build-administration.sh"
      Created "./bin/watch-administration.sh"
  - Configuring shopware/core (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/.htaccess"
      Created "./bin/build-js.sh"
      Created "./bin/ci"
      Created "./bin/console"
      Created "./bin/functions.sh"
      Created "./config/jwt/.gitignore"
      Created "./config/packages/shopware.yaml"
      Created "./custom/.htaccess"
      Created "./custom/apps/.gitignore"
      Created "./custom/plugins/.gitignore"
      Created "./custom/static-plugins/.gitignore"
      Created "./files/.htaccess"
      Created "./public/.htaccess.dist"
      Created "./public/index.php"
      Created "./public/maintenance.html"
      Created "./var/.htaccess"
      Created "./.htaccess"
    Adding environment variable defaults
    Setting parameters
    Adding entries to .gitignore
  -  IGNORING  shopware/core (>=6.4): From github.com/shopware/recipes:main
    Adding Docker Compose definitions to "./docker-compose.yml"
    Adding Docker Compose definitions to "./docker-compose.override.yml"
    Docker Compose definitions have been modified. Please run "docker compose up --build" again to apply the changes.
  - Configuring shopware/elasticsearch (>=6.4): From github.com/shopware/recipes:main
      Created "./config/packages/elasticsearch.yaml"
    Setting parameters
  - Configuring shopware/storefront (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/build-storefront.sh"
      Created "./bin/watch-storefront.sh"
  - Configuring symfony/console (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/debug-bundle (>=5.3): From github.com/symfony/recipes:main
      Created "./config/packages/debug.yaml"
  - Configuring symfony/lock (>=5.2): From github.com/symfony/recipes:main
      Created "./config/packages/lock.yaml"
  - Configuring symfony/mailer (>=4.3): From github.com/symfony/recipes:main
      Created "./config/packages/mailer.yaml"
  - Configuring symfony/messenger (>=6.0): From github.com/shopware/recipes:main
      Created "./config/packages/messenger.yaml"
  - Configuring symfony/monolog-bundle (>=3.3): From github.com/shopware/recipes:main
      Created "./config/packages/dev/monolog.yaml"
      Created "./config/packages/prod/deprecations.yaml"
      Created "./config/packages/prod/monolog.yaml"
      Created "./config/packages/test/monolog.yaml"
  - Configuring symfony/routing (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/translation (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/twig-bundle (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/validator (>=5.3): From github.com/symfony/recipes:main
      Created "./config/packages/validator.yaml"
 Files have been reset to the latest version of the recipe.
  * Use git diff to inspect the changes.
    Not all of the changes will be relevant to your app: you now
    need to selectively add or revert them using e.g. a combination
    of git add -p and git checkout -p
  * Use git checkout . to revert the changes.
    New (untracked) files can be inspected using git clean --dry-run
    Add the new files you want to keep using git add
    then delete the rest using git clean --force
Failed to prepare update
Nach ein bisschen Gefrikkel zwischen php8.1 und 8.2 sowie dem Hochsetzen des memorylimit auf 1024 lief es dann wieder.
Bei mir war dass der Update diese Zeile
Liste der Dateiendungen die als PHP8.1 verarbeitet werden sollen
AddHandler php-fastcgi8.1 .php .phtml
gelöscht bzw. die .htaccess neu erstellt hat.
