ich habe jetzt mehrfach versucht das Update von 6.5.1.1 auf 6.5.3.3 durchzuführen.
Leider klappt es nicht und es bricht ab und spuckt das hier aus:
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
Info from https://repo.packagist.org: #StandWithUkraine
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.010 seconds
Analyzed 878 packages to resolve dependencies
Analyzed 6118 rules to resolve dependencies
Lock file operations: 1 install, 49 updates, 7 removals
Installs: symfony/polyfill-php83:v1.27.0
Updates: symfony/runtime:v6.3.2, symfony/http-client:v6.3.2, symfony/process:v6.3.2, symfony/finder:v6.3.3, symfony/filesystem:v6.3.1, symfony/console:v6.3.2, doctrine/lexer:3.0.0, psr/http-message:1.1, guzzlehttp/psr7:2.5.0, google/auth:v1.28.0, nyholm/psr7:1.8.0, symfony/routing:v6.3.3, symfony/mime:v6.3.3, symfony/http-foundation:v6.3.2, symfony/event-dispatcher:v6.3.2, symfony/error-handler:v6.3.2, symfony/http-kernel:v6.3.3, symfony/var-exporter:v6.3.2, symfony/dependency-injection:v6.3.2, symfony/config:v6.3.2, symfony/cache:v6.3.2, symfony/framework-bundle:v6.3.2, symfony/yaml:v6.3.3, doctrine/annotations:2.0.1, symfony/validator:v6.3.2, symfony/twig-bridge:v6.3.2, symfony/twig-bundle:v6.3.0, symfony/translation:v6.3.3, symfony/stopwatch:v6.3.0, symfony/serializer:v6.3.3, symfony/security-core:v6.3.3, symfony/options-resolver:v6.3.0, symfony/rate-limiter:v6.3.2, symfony/proxy-manager-bridge:v6.3.0, symfony/property-info:v6.3.0, symfony/property-access:v6.3.2, symfony/monolog-bridge:v6.3.1, symfony/clock:v6.3.1, symfony/messenger:v6.3.3, symfony/mailer:v6.3.0, symfony/lock:v6.3.2, symfony/dotenv:v6.3.0, symfony/doctrine-messenger:v6.3.1, symfony/debug-bundle:v6.3.2, symfony/asset:v6.3.0, shopware/core:v6.5.2.0, shopware/administration:v6.5.2.0, shopware/elasticsearch:v6.5.2.0, shopware/storefront:v6.5.2.0
Removals: webmozart/assert, phpstan/phpdoc-parser, phpdocumentor/type-resolver, phpdocumentor/reflection-docblock, phpdocumentor/reflection-common, php-http/message-factory, league/construct-finder
  - Removing league/construct-finder (1.2.2)
  - Removing php-http/message-factory (1.1.0)
  - Removing phpdocumentor/reflection-common (2.2.0)
  - Removing phpdocumentor/reflection-docblock (5.3.0)
  - Removing phpdocumentor/type-resolver (1.7.2)
  - Removing phpstan/phpdoc-parser (1.23.0)
  - Removing webmozart/assert (1.11.0)
  - Upgrading doctrine/annotations (1.14.3 => 2.0.1)
  - Upgrading doctrine/lexer (2.1.0 => 3.0.0)
  - Upgrading google/auth (v1.26.0 => v1.28.0)
  - Upgrading guzzlehttp/psr7 (2.4.5 => 2.5.0)
  - Upgrading nyholm/psr7 (1.6.1 => 1.8.0)
  - Upgrading psr/http-message (1.0.1 => 1.1)
  - Upgrading shopware/administration (v6.5.1.1 => v6.5.2.0)
  - Upgrading shopware/core (v6.5.1.1 => v6.5.2.0)
  - Upgrading shopware/elasticsearch (v6.5.1.1 => v6.5.2.0)
  - Upgrading shopware/storefront (v6.5.1.1 => v6.5.2.0)
  - Upgrading symfony/asset (v6.2.7 => v6.3.0)
  - Upgrading symfony/cache (v6.2.13 => v6.3.2)
  - Upgrading symfony/clock (v6.2.12 => v6.3.1)
  - Upgrading symfony/config (v6.2.13 => v6.3.2)
  - Upgrading symfony/console (v6.2.13 => v6.3.2)
  - Upgrading symfony/debug-bundle (v6.2.13 => v6.3.2)
  - Upgrading symfony/dependency-injection (v6.2.13 => v6.3.2)
  - Upgrading symfony/doctrine-messenger (v6.2.12 => v6.3.1)
  - Upgrading symfony/dotenv (v6.2.8 => v6.3.0)
  - Upgrading symfony/error-handler (v6.2.13 => v6.3.2)
  - Upgrading symfony/event-dispatcher (v6.2.13 => v6.3.2)
  - Upgrading symfony/filesystem (v6.2.12 => v6.3.1)
  - Upgrading symfony/finder (v6.2.14 => v6.3.3)
  - Upgrading symfony/framework-bundle (v6.2.13 => v6.3.2)
  - Upgrading symfony/http-client (v6.2.13 => v6.3.2)
  - Upgrading symfony/http-foundation (v6.2.13 => v6.3.2)
  - Upgrading symfony/http-kernel (v6.2.14 => v6.3.3)
  - Upgrading symfony/lock (v6.2.12 => v6.3.2)
  - Upgrading symfony/mailer (v6.2.12 => v6.3.0)
  - Upgrading symfony/messenger (v6.2.13 => v6.3.3)
  - Upgrading symfony/mime (v6.2.13 => v6.3.3)
  - Upgrading symfony/monolog-bridge (v6.2.8 => v6.3.1)
  - Upgrading symfony/options-resolver (v6.2.7 => v6.3.0)
  - Locking symfony/polyfill-php83 (v1.27.0)
  - Upgrading symfony/process (v6.2.13 => v6.3.2)
  - Upgrading symfony/property-access (v6.2.13 => v6.3.2)
  - Upgrading symfony/property-info (v6.2.11 => v6.3.0)
  - Upgrading symfony/proxy-manager-bridge (v6.2.7 => v6.3.0)
  - Upgrading symfony/rate-limiter (v6.2.13 => v6.3.2)
  - Upgrading symfony/routing (v6.2.13 => v6.3.3)
  - Upgrading symfony/runtime (v6.2.13 => v6.3.2)
  - Upgrading symfony/security-core (v6.2.8 => v6.3.3)
  - Upgrading symfony/serializer (v6.2.13 => v6.3.3)
  - Upgrading symfony/stopwatch (v6.2.7 => v6.3.0)
  - Upgrading symfony/translation (v6.2.11 => v6.3.3)
  - Upgrading symfony/twig-bridge (v6.2.13 => v6.3.2)
  - Upgrading symfony/twig-bundle (v6.2.7 => v6.3.0)
  - Upgrading symfony/validator (v6.2.13 => v6.3.2)
  - Upgrading symfony/var-exporter (v6.2.13 => v6.3.2)
  - Upgrading symfony/yaml (v6.2.10 => v6.3.3)
Writing lock file
Installing dependencies from lock file (including require-dev)
> pre-operations-exec: Symfony\Flex\Flex->recordOperations
Package operations: 1 install, 49 updates, 7 removals
  - Downloading shopware/core (v6.5.2.0)
  - Downloading shopware/administration (v6.5.2.0)
  - Downloading shopware/elasticsearch (v6.5.2.0)
  - Downloading shopware/storefront (v6.5.2.0)
> post-package-uninstall: Symfony\Flex\Flex->record
  - Upgrading symfony/runtime (v6.2.13 => v6.3.2): Extracting archive
> post-package-update: Symfony\Flex\Flex->enableThanksReminder
  - Upgrading symfony/http-client (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/process (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/finder (v6.2.14 => v6.3.3): Extracting archive
  - Upgrading symfony/filesystem (v6.2.12 => v6.3.1): Extracting archive
  - Upgrading symfony/console (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading doctrine/lexer (2.1.0 => 3.0.0): Extracting archive
  - Upgrading psr/http-message (1.0.1 => 1.1): Extracting archive
  - Upgrading guzzlehttp/psr7 (2.4.5 => 2.5.0): Extracting archive
  - Upgrading google/auth (v1.26.0 => v1.28.0): Extracting archive
  - Upgrading nyholm/psr7 (1.6.1 => 1.8.0): Extracting archive
  - Upgrading symfony/routing (v6.2.13 => v6.3.3): Extracting archive
  - Upgrading symfony/mime (v6.2.13 => v6.3.3): Extracting archive
  - Installing symfony/polyfill-php83 (v1.27.0): Extracting archive
  - Upgrading symfony/http-foundation (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/event-dispatcher (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/error-handler (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/http-kernel (v6.2.14 => v6.3.3): Extracting archive
  - Upgrading symfony/var-exporter (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/dependency-injection (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/config (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/cache (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/framework-bundle (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/yaml (v6.2.10 => v6.3.3): Extracting archive
  - Upgrading doctrine/annotations (1.14.3 => 2.0.1): Extracting archive
  - Upgrading symfony/validator (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/twig-bridge (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/twig-bundle (v6.2.7 => v6.3.0): Extracting archive
  - Upgrading symfony/translation (v6.2.11 => v6.3.3): Extracting archive
  - Upgrading symfony/stopwatch (v6.2.7 => v6.3.0): Extracting archive
  - Upgrading symfony/serializer (v6.2.13 => v6.3.3): Extracting archive
  - Upgrading symfony/security-core (v6.2.8 => v6.3.3): Extracting archive
  - Upgrading symfony/options-resolver (v6.2.7 => v6.3.0): Extracting archive
  - Upgrading symfony/rate-limiter (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/proxy-manager-bridge (v6.2.7 => v6.3.0): Extracting archive
  - Upgrading symfony/property-info (v6.2.11 => v6.3.0): Extracting archive
  - Upgrading symfony/property-access (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/monolog-bridge (v6.2.8 => v6.3.1): Extracting archive
  - Upgrading symfony/clock (v6.2.12 => v6.3.1): Extracting archive
  - Upgrading symfony/messenger (v6.2.13 => v6.3.3): Extracting archive
  - Upgrading symfony/mailer (v6.2.12 => v6.3.0): Extracting archive
  - Upgrading symfony/lock (v6.2.12 => v6.3.2): Extracting archive
  - Upgrading symfony/dotenv (v6.2.8 => v6.3.0): Extracting archive
  - Upgrading symfony/doctrine-messenger (v6.2.12 => v6.3.1): Extracting archive
  - Upgrading symfony/debug-bundle (v6.2.13 => v6.3.2): Extracting archive
  - Upgrading symfony/asset (v6.2.7 => v6.3.0): Extracting archive
  - Upgrading shopware/core (v6.5.1.1 => v6.5.2.0): Extracting archive
  - Upgrading shopware/administration (v6.5.1.1 => v6.5.2.0): Extracting archive
  - Upgrading shopware/elasticsearch (v6.5.1.1 => v6.5.2.0): Extracting archive
  - Upgrading shopware/storefront (v6.5.1.1 => v6.5.2.0): Extracting archive
> post-package-install: Symfony\Flex\Flex->recordFlexInstall
Generating optimized autoload files
> post-autoload-dump: Symfony\Component\Runtime\Internal\ComposerPlugin_composer_tmp0->updateAutoloadFile
107 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
> post-update-cmd: Symfony\Flex\Flex->update
What about running composer global require symfony/thanks && composer thanks now?
This will spread some 💖  by sending a ★  to the GitHub repositories of your fellow package maintainers.
Run composer recipes at any time to see the status of your Symfony recipes.
Found 1 security vulnerability advisory affecting 1 package.
Run composer audit for a full list of advisories.
Symfony operations: 18 recipes (23f32e8bd02a9b9ef985988f93a2ab0a)
  - Configuring symfony/flex (>=1.0): From github.com/symfony/recipes:main
    Copying files from recipe
      Created "./.env"
  - Configuring symfony/framework-bundle (>=5.4): From github.com/shopware/recipes:main
    Enabling the package as a Symfony bundle
      Created "./config/services.yaml"
  - Configuring doctrine/annotations (>=1.0): From github.com/shopware/recipes:main
  - Configuring nyholm/psr7 (>=1.0): From github.com/symfony/recipes:main
      Created "./config/packages/nyholm_psr7.yaml"
  - Configuring shopware/administration (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/build-administration.sh"
      Created "./bin/watch-administration.sh"
  - Configuring shopware/core (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/.htaccess"
      Created "./bin/build-js.sh"
      Created "./bin/ci"
      Created "./bin/console"
      Created "./bin/functions.sh"
      Created "./config/jwt/.gitignore"
      Created "./config/packages/shopware.yaml"
      Created "./custom/.htaccess"
      Created "./custom/apps/.gitignore"
      Created "./custom/plugins/.gitignore"
      Created "./custom/static-plugins/.gitignore"
      Created "./files/.htaccess"
      Created "./public/.htaccess.dist"
      Created "./public/index.php"
      Created "./public/maintenance.html"
      Created "./var/.htaccess"
      Created "./.htaccess"
    Adding environment variable defaults
    Setting parameters
    Adding entries to .gitignore
  -  IGNORING  shopware/core (>=6.4): From github.com/shopware/recipes:main
    Adding Docker Compose definitions to "./docker-compose.yml"
    Adding Docker Compose definitions to "./docker-compose.override.yml"
    Docker Compose definitions have been modified. Please run "docker compose up --build" again to apply the changes.
  - Configuring shopware/elasticsearch (>=6.4): From github.com/shopware/recipes:main
      Created "./config/packages/elasticsearch.yaml"
    Setting parameters
  - Configuring shopware/storefront (>=6.4): From github.com/shopware/recipes:main
      Created "./bin/build-storefront.sh"
      Created "./bin/watch-storefront.sh"
  - Configuring symfony/console (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/debug-bundle (>=5.3): From github.com/symfony/recipes:main
      Created "./config/packages/debug.yaml"
  - Configuring symfony/lock (>=5.2): From github.com/symfony/recipes:main
      Created "./config/packages/lock.yaml"
  - Configuring symfony/mailer (>=4.3): From github.com/symfony/recipes:main
      Created "./config/packages/mailer.yaml"
  - Configuring symfony/messenger (>=6.0): From github.com/shopware/recipes:main
      Created "./config/packages/messenger.yaml"
  - Configuring symfony/monolog-bundle (>=3.3): From github.com/shopware/recipes:main
      Created "./config/packages/dev/monolog.yaml"
      Created "./config/packages/prod/deprecations.yaml"
      Created "./config/packages/prod/monolog.yaml"
      Created "./config/packages/test/monolog.yaml"
  - Configuring symfony/routing (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/translation (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/twig-bundle (>=5.4): From github.com/shopware/recipes:main
  - Configuring symfony/validator (>=5.3): From github.com/symfony/recipes:main
      Created "./config/packages/validator.yaml"
 Files have been reset to the latest version of the recipe.
  * Use git diff to inspect the changes.
    Not all of the changes will be relevant to your app: you now
    need to selectively add or revert them using e.g. a combination
    of git add -p and git checkout -p
  * Use git checkout . to revert the changes.
    New (untracked) files can be inspected using git clean --dry-run
    Add the new files you want to keep using git add
    then delete the rest using git clean --force
                INSTALLER
Language
Configuration
Download
Finish
Configuration
PHP binary found. If you want to select the file yourself, you can specify it here.
PHP binary
Back
Save configuration
            DE
            EN
Ich erkenne hier keine Fehlermeldung…
Habe mit PHP 8.1 und 8.2 versucht…
memory_limit = 4096M
max_execution_time = 240
Kann Jemand hier weiterhelfen?
