SSL/TLS mariadb
Hello everyone,
Does shopware can work with a database which enforces SSL connections?
For example, if we have shopware on Amazon cloud and MariaDB on Google Cloud, important is to use an SSL connection.
I’m getting next error:
Hi Ognjen,
Shopware can’t connect to an database that enforces a SLL connection.
You need to modify the source code in order to get this going,
Connection creation: https://github.com/shopware/platform/blob/2b8c0e3d5bf4025f360ec59ed0f24b2dcf9c15ff/src/Core/Kernel.php#L161
https://www.doctrine-project.org/projects/doctrine-dbal/en/2.10/reference/configuration.html#mysqli
ssl parameters
Doctrine Doctrine
Configuration - Doctrine Database Abstraction Layer (DBAL)
Doctrine Database Abstraction Layer Documentation: Configuration
src/Core/Kernel.php:161
            _$parameters = [_
Thanks a lot, @Timmy_Clark‍ .
Shimmy from GitHub sent me a possible solution: SSL/TLS mariadb · Issue #1323 · shopware/platform · GitHub
I will write here when I check it :slight_smile:
