Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. SQLSTATE[42000]: Syntax error or access violation: 1066 Not unique table/alias: ‚ac‘ in Zend/Db/Statement/Pdo.php on line 234 Stack trace: #0 Zend/Db/Statement.php(300): Zend_Db_Statement_Pdo->_execute(Array) #1 Zend/Db/Adapter/Abstract.php(479): Zend_Db_Statement->execute(Array) #2 Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query(’???SELECT SQL_…’, Array) #3 Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend_Db_Adapter_Pdo_Abstract->query(’???SELECT SQL_…’, Array) #4 Zend/Db/Adapter/Abstract.php(736): Enlight_Components_Db_Adapter_Pdo_Mysql->query(’???SELECT SQL_…’, Array) #5 Enlight/Components/Adodb.php(247): Zend_Db_Adapter_Abstract->fetchAll(’???SELECT SQL_…’, Array) #6 Enlight/Components/Adodb.php(393): Enlight_Components_Adodb->GetAll(’???SELECT SQL_…’, Array) #7 Enlight/Components/Adodb.php(410): Enlight_Components_Adodb->callCached(‚GetAll‘, 86400, ‚???SELECT SQL_…‘, false, ‚search_supplier‘) #8 engine/core/class/sArticles.php(714): Enlight_Components_Adodb->CacheGetAll(86400, ‚???SELECT SQL_…‘, false, ‚search_supplier‘) #9 Shopware/Controllers/Frontend/Search.php(52): sArticles->sGetArticlesByName(‚a.name ASC‘, ‚‘, ‚supplier‘, ‚4‘) #10 Enlight/Controller/Action.php(148): Shopware_Controllers_Frontend_Search->supplierSearchAction() #11 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‚supplierSearchA…‘) #12 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #13 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight_Controller_Front->dispatch() #14 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #15 Shopware/Components/HttpCache/AppCache.php(234): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #16 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(403): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #17 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(303): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #18 Shopware/Components/HttpCache/AppCache.php(158): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #19 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #20 Shopware/Components/HttpCache/AppCache.php(110): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #21 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #22 Enlight/Application.php(192): Shopware_Bootstrap->run() #23 shopware.php(83): Enlight_Application->run() #24 {main} Bitte brauche dringend Hilfe!!! Dieser Fehler tritt auf wenn ich in den Artikeldetails auf „Weitere Artikel von …“ klicke.
Hallo, über die Suche findet man direkt die Lösung post66429.html#p66486 Da ist im Template wohl noch ein alter Link Sebastian
Danke für die schnelle Antwort. Jetzt klappt alles wieder.
