Bei der Installation von Shopware Commercial kommt folgender Fehler:
Internal Server Error An exception occurred while executing a query: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‚(JSON_ARRAY()), created_at DATETIME(3) NOT NULL, `u‘ at line
Kann mir hier jemend evtl. helfen ?
